Strange engine #
I'm very confused by the engine # in the picture below. 1082001 is a very odd number for a 1977 930 engine.
Can someone help?
Thanks,
http://917burger.blogspot.com
Old 04-10-2011, 05:31 AM
83 911 Production Cab #10
JJ 911SC's Avatar
K Series Aug 76 - Jul 77
Type 930/53 fitted to US Turbo
The # seem odd as it should be 6870001 +
??? for 108 but the serial is probably 2001
The stamp in front of the number look like PS.
Someone will crack this code
Who Will Live... Will See
Old 04-10-2011, 10:44 AM
Since there are no stars, this would not be a production installed case stamping.
Also , take a photo that shows the stamped digits better . They do not look like production stamp tools for that year either , But I would have to see then better to know for certain.
Old 04-10-2011, 11:20 AM
JJ 911SC's Avatar
Originally Posted by RatBox View Post
Since there are no stars, this would not be a production installed case stamping...
PS... Porsche Spare or Porsche Special
Old 04-10-2011, 12:16 PM
Unfortunately , it's usually not that easy. IF.... it is a porsche stamping (away from production engine buiding stations). Letters similar to this usually are abbreviations for a DE word / or words.
Spare / Ersatzteil
Special does start with an S in DE however / Sonder or Spezial
The normally used/seen stampings for Factory built (or built in Porsche Facilities in other countries) replacement motors are AT , and KD. And the following stampings are usually similar to the motor they are replacing.
I did find a blurb about how 911 Carrera 3.2 CS's have 'SP' stamped into the cases. But I do not know where the stamping is. And if this truly is a fact. Or if a fact , what SP stands for.
Old 04-10-2011, 01:35 PM
If you looked at as a date and a product number.
Years ago I had heard that some builders would emboss with their number on a rebuild. Possibly the builders initials build date and sequence number.
Just a thought
Bruce
Old 04-10-2011, 02:03 PM
The numbers appears to be original from the factory, there are no signs of sanding or grinding the engine case to apply a different number (post assembly ).
The engine does have the engine type (930/53) which is correct for this model year.
I would like to sort this out before disassembling the engine for the rebuild.
Thanks,
Old 04-10-2011, 02:21 PM
If you would like any more help from me. I have to see the stamped numeral digits better. And i'm curious , do you think this kind of info. just gets handed to you on a platter ?
Porsche used many Font stamping tools over the years . And reused them depending on who and where in the factory the stamping was done.
Old 04-10-2011, 02:37 PM
Thanks for all the help, I'll get better pictures of the stampings tomorrow.
Old 04-10-2011, 02:39 PM
