Strange engine #
I'm very confused by the engine # in the picture below. 1082001 is a very odd number for a 1977 930 engine.
Can someone help? Thanks,
http://917burger.blogspot.com |
83 911 Production Cab #10
K Series Aug 76 - Jul 77
Type 930/53 fitted to US Turbo The # seem odd as it should be 6870001 + ??? for 108 but the serial is probably 2001 The stamp in front of the number look like PS. Someone will crack this code
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Since there are no stars, this would not be a production installed case stamping.
Also , take a photo that shows the stamped digits better . They do not look like production stamp tools for that year either , But I would have to see then better to know for certain. Last edited by RatBox; 04-10-2011 at 12:32 PM.. |
Unfortunately , it's usually not that easy. IF.... it is a porsche stamping (away from production engine buiding stations). Letters similar to this usually are abbreviations for a DE word / or words.
Spare / Ersatzteil Special does start with an S in DE however / Sonder or Spezial The normally used/seen stampings for Factory built (or built in Porsche Facilities in other countries) replacement motors are AT , and KD. And the following stampings are usually similar to the motor they are replacing. I did find a blurb about how 911 Carrera 3.2 CS's have 'SP' stamped into the cases. But I do not know where the stamping is. And if this truly is a fact. Or if a fact , what SP stands for. Last edited by RatBox; 04-10-2011 at 02:56 PM.. |
If you looked at as a date and a product number.
Years ago I had heard that some builders would emboss with their number on a rebuild. Possibly the builders initials build date and sequence number. Just a thought Bruce |
The numbers appears to be original from the factory, there are no signs of sanding or grinding the engine case to apply a different number (post assembly ).
The engine does have the engine type (930/53) which is correct for this model year. I would like to sort this out before disassembling the engine for the rebuild. Thanks,
If you would like any more help from me. I have to see the stamped numeral digits better. And i'm curious , do you think this kind of info. just gets handed to you on a platter ?
Porsche used many Font stamping tools over the years . And reused them depending on who and where in the factory the stamping was done. |
Thanks for all the help, I'll get better pictures of the stampings tomorrow.
