Your right. Servicing the emergency brake does not require bearing removal unless you want to.
Guys,
Remember this is a 930 with taper roller bearings for the rear wheel bearing. Yes, first remove the axle assembly with stub axle attached. Pushing on the stub axle while pulling on the hub may collapse the axial 'plunge clearance' of the CV joints and break the CV joint cages. I would plan on fresh grease for the rear wheel bearings and new lip seals. Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
That's just the way it is sometimes. That is, unless there are two piece e-brake support plates. but of course there are not!
1986 930 EFI, twin plug, lovin the sport seats |
I've been cornfused by this thread, but maybe the 930 backing plate is different from mine. I took the backing plate off in order to pull my hub, and then replace the bearing with the puller.
