Setting Spring Plate Angle on Un-level Car
Hello,
I'm about to set my spring plates using Will Ferch's angle calculator; I'm guessing that this should be done with the car body level. I like the stability of having my front wheels on the ground and so I wondering If I can set my inclinometer on the door sill and subtract that reading from the number generated by the calculator and then set the spring plates to the difference?
Rutager West
Old 04-12-2011, 02:40 PM
Northern Motorhead
wildcat077's Avatar
Yup,
That's the way to do it ... I did mine last Summer with a small digital level and it worked out great,although i had the car up on all fours and pretty close to zero degrees on the door sills.
Have fun
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 04-12-2011, 03:01 PM
Member 911 Anonymous
DRACO A5OG's Avatar
+1 ^^^
'85 Carrera Targa
PCA/POC
Old 04-12-2011, 04:10 PM
Danimal16's Avatar
What you are describing is just the method in the late Shop Manual.
Dan
Old 04-12-2011, 06:48 PM
Thanks Guys,
I figured it would work, but I figure lots of stuff will work and then they don't!!!!!!!!
This will be a lot easier then trying to get the front jacked up safely and without damaging anything.
-Rutager
Rutager West
Old 04-13-2011, 12:52 AM
Northern Motorhead
wildcat077's Avatar
Wow,i didn't know there was a late shop manual
Cheers !
Phil
Cheers
Phil
Old 04-13-2011, 02:13 AM
ivangene's Avatar
BTW there is an "APP" for that if you have a smart or iPhone - no math needed, just zero it on the sill
Ed M
86' Coupe
Old 04-13-2011, 04:56 AM
Danimal16's Avatar
Cheers !
Phil
It is the 84-89 manual. This is the link:
http://www.cannell.co.uk/911_72-89_Workshop_Manuals/84-89%20Workshop%20Manual.pdf
You can down load it for free. Go to the rear axle and it shows the math. it is good stuff.
DanB
Dan
Old 04-13-2011, 08:52 AM
Northern Motorhead
wildcat077's Avatar
Dan,
Thank you for the link,i have it on a CD which the PO gave me when i bought my car ...
It's already downloaded,printed and separated in plastic sleeves (dirty finger proof) and organized in different chapters. Keeps my Bentley clean
I'm sure a lot of people will appreciate the link !
Cheers !
Phil
Cheers
Phil
Old 04-13-2011, 12:09 PM
Danimal16's Avatar
Dan,
Cheers !
Phil
Phil,
You are welcome. When I saw the section that we have been discussing I tought that it was kool! The last PO did you goooood!
DanB
Dan
Old 04-13-2011, 12:28 PM
Section 420-16 of that bootleg manual works only to describe the spring-plate angle setting for stock torsion bar diameters of our cars,and then only to come to stock ride height....although it has the good point of advising 1 degree less angle for cars that have hi-pressire gas charged shocks.
The spring plate angle calculater used by this group, is more flexible in that it allows a different ( than stock) ride height and also can accommodate different diameter torsion bars.
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 04-13-2011, 12:56 PM
Ohh...RWest..... the calculator knows that the car will never be totally level, and if the car on 4 jackstands is off by say 1-5 degrees or so.....yes...add or subtract to "correct".
Just a small caution......if the discrepency from horizontal is major....like maybe 45 degrees offset.....then there might be some new errors introduced into the equations that may not be properly accounted for. I can't put my finger on where the problem may lie....but big offsets may mess things up a bit...maybe not by much, if at all. But I thoght to throw the warning out.
Wil Ferch
Old 04-13-2011, 01:14 PM
Danimal16's Avatar
Wil,
GREAT POINT. I used your calculator with the procedure described in the manual. So instead of the 33 degrees (or whatever) for the stock setting I used the setting from your calculator for the 27mm bars I upgraded to. Went with 23.6 degrees and it came out perfect. The car, however sat on the lift at a 5.9 degree tilt and the method for calculating it was in the Shop Manual. SOOOOO you are correct, the use of your calculator to find the setting and using the calculation method in the Workshop Manual is a hand in hand operation.
Danb
Dan
Old 04-13-2011, 03:09 PM
Will,
I'll check my angle and if its too much, I'll get the front up some and do the math.
Thanks for the help, and thanks even more for putting out the calculator!
Thanks everyone for verifing this and all your other information.
-Rutager
Rutager West
Old 04-14-2011, 02:30 PM
Danimal16's Avatar
Rutager,
In my case, my car was at a 5.9 degree angle at the sill plate. It was not level.
I used Wil's calculator to determine that my spring plate angle for my suspension was 23 degrees. So I subtracted the 5.9 degrees from the 23 degrees and set the spring plate at 16.1 degrees and it was spot on. I have upgraded to the factory adjustable spring plate and I set the spring plate in the middle to enable me to go up or down. It worked out very nicely.
DanB
Dan
Old 04-14-2011, 02:34 PM
Well then.....even better...a bit less to worry about.... !
Wil Ferch
Old 04-16-2011, 12:28 PM
