Greek55's Avatar
A/C sometimes works, sometimes doesn't.
I am trying to figure out why my air-condition sometimes will cut on fine and other times I cut the fan switch on and nothing happens. I have run 12 volts to the compressor and evaporator fan and both work. All fusses and relays check out fine. Right now, nothing happens when I cut the fan on.
What tests do I need to run to figure this out?
Smoke
1982 911SC Rosewood
SCWDP # 0097
Old 04-15-2011, 07:36 PM
al lkosmal's Avatar
Often there is a low pressure switch and high pressure switch in the AC system. If either of them trip, they may cut power to the compressor clutch. If you know your way around a Multi-meter, you can check if these switches are open or closed, during operation. However, the switches typically trip to indicate a fault. Low pressure can indicate a system leak and/or low charge, high pressure may indicate blockage, etc....so just replacing switches may not fix a problem. Also....your compressor clutch may be zapping out....either shorting to ground or open. Measure the resistance across the clutch wires. If I remember the resistance will be between 2.5 ohms and 5 ohms. If above or below...it may be clutch time. Also check the continuity of the 12V supply from the thermostat all the way to the compressor. That's all i know...maybe an ac expert will jump in.
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 04-15-2011, 09:59 PM
Mitch Leland's Avatar
Al,
Do you know for a fact that your system is charged with adequate refrigerant?
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 04-15-2011, 10:17 PM
pete3799's Avatar
What Al said.
Also check the relay in the smugglers box.
Pete
79 911SC RoW
Old 04-16-2011, 06:58 AM
wwest's Avatar
I'm pretty sure that for an '83 the only compressor clutch control cycling is the thermostat's capillary tube/bulb. Used to "sense" the temperature on the face of the evaporator. Not altogether unusual for those to fail in a manner, switch contacts AT the thermostat itself, that result in no compressor operation.
Old 04-16-2011, 07:20 AM
