corysurf's Avatar
Send a message via AIM to corysurf
Can't get it started.
I may have posted this question already, but I don't see it on the board so I don't think it went through.
Anyways, I cannot get my '71 911T started. I have replaced plugs, wires, points, rotor, cap, coil. I am getting spark at the plugs. I checked the firing order and 2 months ago before I had the car it ran for about an hour then stopped and has not started since. I have not gotten the chance to check the timing, but it has not been changed since it last ran. Also when replaced the points I had trouble setting the gap, what is an easy way to turn the engine?, I can't do it by hand, and the starte never seems turn it around to the spot I want. I also replaced the fuel filter on this car, and the pump it getting fuel to the carbs (Zenith 40TIN.) The only thing that happens when I start the car is that is turns over, it doesn't smoke or sputter or anything except occaisonally it will pop and a puff of smoke will come out the exhaust. Could the gas have gone bad? I added water remover to the tank to make sure, and there is gas in the tank. Could the carbs to clogged? Any suggestions on getting her running again. Thanks.
Old 02-19-2002, 02:48 PM
jkeyzer's Avatar
Your post is already on the BBS and has been replied to - check it out from the main page. You might have to refresh in your web browser.
Jeff Keyzer
72 914 w/2056 built by Mark DeBernardi @ Original Customs
Megasquirt with MSII upgrade
Old 02-19-2002, 02:53 PM
