Tracing a wiper problem
My wipers come on everytime I start the car, regardless of the position of the lever.
Once the car is going they will finally stop, but not without a number of "ups and downs" on the lever (with no particular order). From that point forward, they seem to work ok.
What should my troubleshooting path look like ?
Also, when I bought the car, the windshield washer assembly (jug and lines) were disconnected. Does anyone have a source for telling how this part should be connected ?
Thanks in advance.
Jim
Old 02-22-2002, 09:54 AM
Early_S_Man's Avatar
Porsche Crest
Jim,
The washer only needs 3 sectiions of hose and a 'Tee' between the pump and squirters.
The wiper motor MAY have a problem ... dirt, or corrosion on the 'homing' contacts inside the motor. But that doesn't explain why the problem occurs every time you start the car. A control-stalk switch contact problem seems likely. You may be able to correct the problem by bending the contacts with needle-nose pliers ... after removing the plastic control-stalk covers.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 02-22-2002, 10:55 AM
