Need help with torque specs
So my shocks have finally arrived back from rennsport!!!! Tomorrow I will be installing them along with motor mounts. Not wanting to screw anything up what are the correct torque specs for the following-
all motor/trans mount bolts
top of front shock
bottom of rear shock going into trailing arm
front rotor onto hub
bolts that hold calipers onto strut/trailing arm
Thanks in advance, its finally coming together
1976 Porsche 911s-Balanced and blueprinted 2.7, Rennsport bilstiens, 21/27 hollow tbars, rennline strut brace/strut monoballs, poly front bushings, neatrix rear bushings, Hawk pads, SSI's, M&K 2 in 1 out, 15x7 fuchs wrapped with yoko s-drives, turbo tie rods, steering rack raiser, and JL stereo.
Avid national kart competitor at the sharp end of the field-sponsors welcome
Old 05-02-2011, 06:05 PM
Anybody?
Old 05-04-2011, 08:58 AM
Less brakes, more gas!
euro911sc's Avatar
You need to buy a little spec book. Reprints are available from Pelican (I think) and Porsche. Has all the torque specs in there as well as measurement and wear specs.
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 05-04-2011, 09:01 AM
KTL KTL is online now
Schleprock
KTL's Avatar
The motor and trans mount bolts are 58 ft-lb for the large M14 bolts. Anti seize highly recommended here. The smaller M8 bolts for the mounts themselves (mounting them to the rear chassis and trans crossmember) is the typical 18 ft-lb dry
The top of the front shock depends on your shock. If it's a standard Bilstein or Boge, it is also rather high at 58 ft-lb dry I believe
Bottom of rear shock is 92 ft-lb if you've got aluminum trailing arms. Not sure about the steel trailing arm spec. Anti seize is acceptable/recommended here.
Front rotor onto hub is M8 torque spec = 18 ft-lb dry
Front caliper mounts are 52 ft-lb I believe for original iron calipers, anti seize recommended. Rear calipers cannot be effectively torqued, so simply snug them down with a bit of grunt from your 19mm box end wrench
Going by memory (I check this stuff all the time on my racecar) I am confident in all of the above except the front shock and front caliper, because mine on my racecar are no longer original parts- I have Bilstein coilovers and 993-adapted calipers in front now. I will confirm the values later on, if no one else responds before I get home. That said, I wholeheartedly agree that a Porsche spec book or the Bentley manual are a must to have some good torque spec information handy.
Kevin L
'86 Carrera "Larry"
Old 05-04-2011, 10:18 AM
Thanks a million, thats perfect
Old 05-04-2011, 11:15 AM
