-   -   Engine knocking noise...need help identifying (http://forums.pelicanparts.com/porsche-911-technical-forum/606917-engine-knocking-noise-need-help-identifying.html)
maxhofer 05-09-2011 08:04 AM
Originally Posted by DRACO A5OG (Post 6010828)
What kind of oil are you using or used?
Draco, I'm using Liqui-Moly 20W-50 non-synthetic.
hcoles 05-09-2011 08:14 AM
re. mechanics stethoscope, I've read and tried using a wooden dowel. For some reason(s) it seemed to filter out the unwanted noise. Just put one end on the engine spot of interest and hold it against your ear.
maxhofer 05-09-2011 08:19 AM
I'm picking one up this p.m. Due to mother's day I couldn't work on the car during the weekend, but i'll jump on it today.
Tazzieman's noise sounds very much like mine.
DRACO A5OG 05-09-2011 03:00 PM
The reason I asked, I had the "Rumbling/Rattling Metal Trash Can" noise 2 years ago.
Drove on the freeway at moderate speed enjoying a drive to the beach then all of a sudden, the rumble noise occurred.:eek:
Limped home and took both fans off, used a stehtescope and verified the noise was coming from the driverside chain cover. I was ready to take her in the next day but the noise disappeared. Weird.
About a year ago, it came back for a day then went away again. Strange.
2 years ago, I started to use different brand of oil (not liqui-moly) but Mobil 1 synth to Dino/Synth mix. I thought to me is was to too much of a coincedense. Now I use straight Dino, have not heard the Rumble of the Trash Can yet. If it does, then I guess it will be time to tear her apart to take a peak inside.
j911brick 05-10-2011 01:22 AM
if its not the chain tensioner I would guess intermediate shaft bearings.
maxhofer 05-16-2011 11:04 AM
UPDATE:
Ok, here's what I've found so far. I went for the chain tensioners first.
This is how the passenger side cover looked like before opening:
http://forums.pelicanparts.com/uploa...1305564998.jpg
As you can see cover was very dirty and with signs of oil dripping around the bottom.
This is how the driver's side cover looked before opening:
http://forums.pelicanparts.com/uploa...1305565347.jpg
http://forums.pelicanparts.com/uploa...1305565394.jpg
As you can see, the driver's side cover was very clean and with very little oil dripping from the bottom.
When I disconnected the oil tube from the passenger/right side a lot of oil came out. BUT when I disconnected the tube from the driver/left side very little oil came out.
When I opened the passenger cover a lot of oil dripped from inside also. BUT AGAIN, when I opened the driver's side very little oil came out from inside the case.
Can it be that I was getting less oil into the left side than into the right side?
A look at the inside of the cases:
Passenger/Right side Case:
http://forums.pelicanparts.com/uploa...1305566055.jpg
http://forums.pelicanparts.com/uploa...1305566076.jpg
Driver's/Left side Case:
http://forums.pelicanparts.com/uploa...1305566303.jpg
http://forums.pelicanparts.com/uploa...1305566321.jpg
On the tensioners:
I pressed on the passenger/right side chain and the tensioner's piston did not move at all. I also tried to press the piston itself, but it was hard as a rock.
BUT, when I pressed the driver's/left side chain the piston compressed inmediatelly. Here is a couple of videos of the action:
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/oeyEQrTGjnc?hl=es&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/oeyEQrTGjnc?hl=es&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/dzPQpFxQ2ck?hl=es&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/dzPQpFxQ2ck?hl=es&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
I checked both of the oil tubes going into the cases/tensioners and they both were unclogged.
Can it be that my driver's/left tensioner wasn't getting enough oil pressure? Or is it definetely failed?
The difference in the amount of oil that came out from both of the cases makes me wonder if the problem is oil circulation.
Another find!!!:
When I removed the driver's/left cover I found a small metal piece that looks a piece of wrinkled aluminum foil (a bit thicker).
It was sticking to the inside of the cover:
http://forums.pelicanparts.com/uploa...1305568402.jpg
http://forums.pelicanparts.com/uploa...1305568436.jpg
http://forums.pelicanparts.com/uploa...1305568458.jpg
Any idea of where this piece of metal could have come from????
Again, any ideas, guesses, comments will be greatly appreciated!!!
Max.
j911brick 05-16-2011 11:56 AM
I might consider putting it back together and testing the oil pressure on each side. I would also check the left cam for starvation. Given that hunk of metal, the left port may be clogged. But that is the least of your problems. That hunk of metal looks like part of a bearing shell. Pull the IMS cover off and see if you can detect any movement with the IMS by tugging on the chains. I'm still leaning towards defective IMS bearings.
maxhofer 05-16-2011 12:48 PM
Thanks James, I'll pull the IMS cover off and see what I find. Will post results.
Tim L 05-16-2011 01:27 PM
I would drain the oil and see if you don't have a lot of bearing material on the magnetic plug. it could be a failed rod bearing.
maxhofer 05-16-2011 01:30 PM
Good idea, will do that too.
maxhofer 05-16-2011 04:29 PM
Question for j911brick:
James, I'm working with the engine on the car. To get to the intermediate shaft cover I guess I'll have to go on to a partial engine drop as the cover is behind the engine support bracket.
Am I right?
Max.
4sd911 05-16-2011 06:01 PM
Right you have to remove the engine mount.
Look on top of the tensioners in the recessed hole next to the piston rod there should be a raised cap with a open hole at top, are they still there?
maxhofer 05-16-2011 06:30 PM
4sd911, here are pictures of the tensioners, am I missing the caps?:
Driver's/Left Right side tensioner:
http://forums.pelicanparts.com/uploa...1305595703.jpg
Passenger/Right side tensioner:
http://forums.pelicanparts.com/uploa...1305595793.jpg
Dan J 05-16-2011 07:12 PM
I hate to say it but that's a rod bearing. Failed rods have a very particular noise and that's it
The piece of metal is a piece of bearing
maxhofer 05-16-2011 07:56 PM
But, can a piece of rod bearing get into the left chain case?
4sd911 05-16-2011 08:16 PM
The caps are both in place on the tensioners.
4sd911 05-16-2011 08:23 PM
Have you looked behind the valve covers yet?
maxhofer 05-16-2011 08:43 PM
Not yet, will do it tomorrow.
Guess I'll be looking for a broken valve spring, loose rocker or broken rocker shaft.
4sd911 05-16-2011 11:23 PM
Yes, also look at the cam lobes if the spray bar is clogged a rocker could dig into it. The bearing failure is a possibility but is easier to inspect behind the covers first.
Metal pieces floating in the oil on the bottom of the case can make there way to the chains and end up in the chain boxes.
j911brick 05-17-2011 01:02 AM
You don't exactly have to do a partial engine drop. You could just support the engine from the bottom and remove the muffler and engine mount. Probably easier to work with if you just drop the motor though. Either way there is a good chance the motor has to come out so prepare for that. Your probably not going to learn much under the valve cover That kind of material won't come from there. The poster that suggested rod bearings may me right. IMS bearings, which are about the thing as rod bearings, will usually have copper in them. SOunds more like a IMS bearing than a rod bearing to me. IMS bearing failure sounds like a chain tensioner failure; Rod bearing usually sounds slower and heavier. As previously suggested, best bet at the moment will be to pull the sump plate and open up the oil filter. Any flakes and you need a new motor. Sorry.
