Engine knocking noise...need help identifying
Please help me identify this engine noise. It started after some hard driving.
There is no knocking noise at idle, but it starts as soon as I accelerate. <object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/q0jl9pjw9r8?hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/q0jl9pjw9r8?hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object> Any clues will be appreciated. Max. |
I'm not sure but my first thought is timing chain noise? It sounds like the chain slapping in it's housing. It looks like you have a 3.2L engine so I'm guessing you have the pressure fed tensioners. I thought these were less prone to failure so a collapsed tensioner is less probable. Anyone else have an idea?
Thanks Rich, in fact its a 3.2 engine, my car is a 1985 3.2L 911.
Place the metal end of a large screwdriver on the chain box and the other end in your ear and rev the engine a little. If it is the chain / tensioners you will know.
Sounds like a valve not getting back out of the way fast enough, look for a broken valve spring.
Bruce |
The correct tool for your investigation.......
If you could borrow a mechanic's stethoscope, this would give you a better sense where the noise is coming from inside the running engine. Even with my bad hearing, the sound/noise it picks up is so sensitive and clear.
http://forums.pelicanparts.com/uploa...1304652144.jpg Tony |
Very strong possibility of failed tensioner
I had a failed tensioner on my 88 3.2. The noise went away at about 2000 rpm. I changed both.
They can be changed with the engine in the car. |
Wow, that is the classic "chain drug over a metal trash can" sound of a failed tensioner. You don't want to be driving around until you fix that.
Thanks everybody for your answers.
Looks like that the main suspect is a failed tensioner...in fact, when I tried to identify where the noise was coming from, it seemed to be coming from the center rather from one of the sides (i.e. valve trains). As suggested by Pete and Tony I'll do the "screwdriver listening test" (or stethoscope if I get hold of one) this afternoon. I'll post my findings. Max H. |
Stethoscope at Autozone for about $12. Good luck, my guess, flat6pac, valve. Steve
Steve - $3.99 at HFT but maxhofer is in Chile. Screwdriver (without a necktie) in the short term.
Mechanic's Stethoscope. I have never heard the chain over the garbage can noise. This tapping noise is very distinct and very uniform. I am leaning towards valve as well. |
Speaking from never hearing the rattle noise I am thinking the tapping noise would be a little less uniform if tensioners but that is simply the layman speaking. |
YouTube - failing tensioner Nasty noise! |
Yep - thanks for finding that video for me. It does have a uniform noise.
What kind of oil are you using or used?
| All times are GMT -8. The time now is 05:53 PM. |
