dickster's Avatar
allen key size on muffler strap hex nuts??
ok its taken 12 hours (with the help of a local shop) to get the cat. off, clean up the flanges and replace with new nuts/bolts.
now i need to remove the muffler straps and they appear to be held by allen headed nuts (like the heat exch), anyone know what size allen i need.
thanks in advance
i'm covered in crap so i'm going to have a long hot bath!!
Rich
'86 coupe
"there you are"
Old 02-23-2002, 08:41 AM
makaio's Avatar
8 mm. Good luck!
One point to about allen head sockets or wrenches. I have found that the cheap ones from discount stores can vary in tolerance quit a bit. Thus a 10mm wrench might actually be a 9mm or 9.5mm. Which just strips the head out if the bolt is frozen. So I recomend buying the higher quality ones. The muffler straps shouldn't give you too much fuss, but on thigs like heat exchangers, or the starter bolts, you need the good stuff.
Old 02-23-2002, 08:51 AM
dickster's Avatar
mucho thanks to you.
Rich
'86 coupe
"there you are"
Old 02-23-2002, 09:40 AM
Early_S_Man's Avatar
Porsche Crest
Two possibilities here ... the muffler strap uses M10 fasteners ... so, if it is an Allen bolt, it would be an 8 mm hex drive bit or key. But, barrel nuts on M10 fasteners take 10 mm bit or key!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 02-23-2002, 09:44 AM
KTL KTL is offline
Schleprock
KTL's Avatar
The strap bolts can seize up as well. Mostly due to crud, not heat like the exchangers. I couldn't get one of the bolts to back out, so I had to snip the strap. Good luck.
Kevin L
'86 Carrera "Larry"
Old 02-23-2002, 09:45 PM
dickster's Avatar
it was 8mm key, but they ain't budgin.
yeah kevin you're right, i got to snip them and replace!!
Rich
'86 coupe
"there you are"
Old 02-24-2002, 08:14 AM
dickster's Avatar
just ordered new straps.
can you believe those f&^%$£s are £20 ($30) each!!
i'll make sure i buy a can of grease..............
Rich
'86 coupe
"there you are"
Old 02-24-2002, 08:42 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
I would suggest anti-seize instead of grease.
The grease will dissappear after a while, but the anti-seize will hang in there for years.
Bob Hutson
Old 02-24-2002, 09:32 AM
dickster's Avatar
bob i'll look out for it......
thanks
Rich
'86 coupe
"there you are"
Old 02-25-2002, 12:37 AM
