nippy's Avatar
Cant see out rear view mirror...what do you do?
I cant see anything out my rearview because of the roll cage.My instructor got in the car and went to adjust for his drive and said thats not good at all.Leaving me with only side mirrors to use.Im assuming this is normal?Do I lower the mirror on the windshield?Is there a product or something?I was prepared to just get used to it, but he made me feel like it needs to be fixed.
Old 05-09-2011, 09:17 PM
RETIRED
Joe Bob's Avatar
Look into Wink mirrors.....the standard attachment for the mirror will never come off when you want it to...I've seen some that crack the windshield.
Vehicle Codes require either "functional" dual outside or a single driver and center mount mirror.
2012 ML350 3.0 Turbo Diesel
Old 05-09-2011, 09:32 PM
skinnerd's Avatar
Dang man.....what's that cage of yours look like?
My roll bar doesn't hinder my rearview vision at all.
That said, when I used to club race my car, I also had one of those Wink (5 panel) mirrors as well.
Took a little getting used to, as is shows you "so much" of what is behind you.
Needed to learn how to filter thru all that visual info quickly while on the track.
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 05-09-2011, 10:26 PM
Turboo934's Avatar
Turn the mirror upside down .
Robert. 1976 930/934 Turbo Carrera RRS, Cristine She can be evil but oooh so much fun
Old 05-09-2011, 10:49 PM
Senior Advisor
James Brown's Avatar
if your at the front or at the back, you don't need a mirror.
08 Cayenne Turbo
Old 05-09-2011, 10:55 PM
WPOZZZ's Avatar
Here.
YouTube - What's Behind Me, It's Not Important
Old 05-09-2011, 11:01 PM
Almost Banned Once
sc_rufctr's Avatar
Originally Posted by skinnerd View Post
MKIII Styley
- Peter
Old 05-10-2011, 03:01 AM
gchappel's Avatar
I had the same problem- had a windshield shop remount my mirror about 5-6 cm lower on the windshield- problem solved.
Gary
Old 05-10-2011, 03:19 AM
Southern Class & Sass
Dixie's Avatar
As stated earlier... Turn the mirror upside down. The mirror will suddenly be lower.
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 05-10-2011, 03:57 AM
cycling has-been
bkreigsr's Avatar
Dang man.....My roll bar doesn't hinder my rearview vision at all.
that's because you don't have a sun roof. The sun roof necessitates the top cross piece of the roll bar sit about 3" lower in the cabin - almost right in the middle of sight line out the back glass. - even more when you start to add the required padding.
Bill K
Old 05-10-2011, 05:38 AM
nippy's Avatar
upside down does help but still not great....will just deal with it I guess.
Old 05-10-2011, 02:57 PM
You can remove the puck from the windshield by holding a lighter under it, flame not touching the glass or the metal.
Put gentle pressure on the mirror while the flame is under it, it will come right off in 10-15 seconds.
Clean up the puck with a razor blade and alcohol.
Get the 'heavy duty' mirror stick-on glue at auto parts and glue it back on where you want it. Glue the puck on, wait 24 hours before you put the mirror back on the puck.
That's how my pro windshield guy moved the mirror to the new windshield, and I've done it a couple times since.
Old 05-10-2011, 04:24 PM
