Fast blink - only during first few minutes
My 80 SC has a weird issue with fast turn signal blinkers, both left and right. I've read this could be caused by a bad or loose bulb, or dirty contact, etc. I've checked my bulbs and cleaned out any dirt and contamination. They all looked pretty clean, but I sprayed electrical contact cleaner inside the housing, etc., just to be sure.
The strange thing about this issue is that it always seems to 'resolve' itself after a few minutes of driving. It's like the issue is eliminated once the car is warmed up. Its very consistent, never have a fast blink after a few minutes of driving. Does anyone have any suggestions as to what could cause a 'time sensitive' fast blink on the turn signals? Thank
1980 911 ROW SC Coupe 2014 BMW 328i touring 1999 Porsche 911 C2 |
Just a guess: The relay could be on its' way out. When the relay is cold - fast blink. Relay warms up - all is well.
I would replace all the bulbs and relay. It won't be too expensive. I have a 944 that the blinkers don't work at all for a few minutes if the car sits more than a couple days.
james www.gruppe9autowerks.com Its not how fast you go...its how you go fast |
make sure the bulb sockets are clean along with grounds. sounds like a high resistance problem
Thanks all for your responses...I'm ordering new relay and bulbs all around from our host. I will update with my findings on this strange issue.
BEST! Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Bad ground.
Bob F. 1984 Carrera Factory Turbo-Look |
