Packy's Avatar
Angry grinding- second gear
I get a grinding at times that seem to only be in second gear, low rpms and right hand turns. I am really stumped. The grinding seems to be coming from the right rear wheel. It doesn't always happen with every turn I described but when it does it goes like this: I'll slow down in second gear, rpms about 1500, turn in and as soon as I push on the throttle I get a grinding sound. It is LOUD. It is louder under acceleration but goes away after I speed up or lift my foot off the throttle. Again, the sound does seem to be coming from the wheel not the tranny.
I was figuring it is either a wheel bearing, CV or a dreaded tranny/differential problem.
Tranny/differential:
doesn't sound like it is from the tranny but it only seems to be 2nd gear. I don't take turns like this in third and I am going to fast to downshift into first so I don't really know if it actually happens in other gears.
CV's:
My CVs are new and I have had CVs go out before and it usually sounds more like a clicking sound than a grinding sound.
Bearings:
I know bearings grind when under acceleration while turning if a race is worn. I have also heard I could maybe just tighten down the big ass nut on the outside of the hub.
Advice? Suggestions? Road tests?
(1) '77 Chassis and '79 SC 3.0 project car
(1) '79 911SC 3.0 Widebody SC
(1) '15 Ford F-150 4x4 3.5TT
Toluca Lake, CA
Old 05-13-2011, 03:50 PM
is it lsd ? I had some plates break in my lsd and it was a horrendous grinding in turns.S
Old 05-13-2011, 04:11 PM
Packy's Avatar
no, open diff. I wish it was a LSD.
Toluca Lake, CA
Old 05-13-2011, 04:15 PM
Packy's Avatar
Bump. Nobody?
Toluca Lake, CA
Old 05-16-2011, 09:31 AM
Originally Posted by Packy View Post
Bump. Nobody?
Call me; its faster than a long protracted series of posts
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 05-16-2011, 09:58 AM
Packy's Avatar
Will do Steve. I'll try to give you a call this afternoon.
Thanks,
Toluca Lake, CA
Old 05-16-2011, 10:00 AM
Packy's Avatar
I talked with Steve at Rennsport who told me to jack up the car and use a stethoscope to listen to the difference in the wheel bearings and the transmission. So I did and it was very obvious that it wasn't a transmission carrier bearing. It wasn't a right wheel bearing. It is the RIGHT wheel bearing. So I have that going for me. At least my labor is cheap. A tranny rebuild would have sucked.
Anyhow, thanks Steve. I appreciate the advice.
Toluca Lake, CA
Old 05-26-2011, 10:58 AM
Somatic Negative Optimist
Gunter's Avatar
Cool
Is it the right wheel bearing?
If so, consider doing both.
Rear Wheel Bearing Removal
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 05-26-2011, 11:48 AM
Tags
grinding , rear wheel bearing , transmission.
