XLR8'd Member
Wheel nut torque
Can someone tell me the right torque for wheel nuts on a 996 4s tracked once per summer ?
David (mechanic wanabe) 2002 Carrera 4S (replacement for an 84 coupe) 06 Acura CSX (wife beater) 05 Acura MDX (toy hauler) http://www.pelicanparts.com/gallery/david_84_911 |
It's not in the owners manual?
Sold: 1989 3.2 coupe, 112k miles |
Correct torque spec for the wheel bolts is 130Nm (96 ft.lbs)
I think the 911 series has used that for a long time. I have 94 written on my garage wall, adjusted because I lubricate the threads.
[QUOTE=hcoles;6808603...adjusted...[/QUOTE]
To? TIA!
'90C4 |
Formerly known as Syzygy
Torque specs automatically assume threads are lubed/not dry. Except for two things (or was it one?) that I can't remember, but they aren't lug nuts.
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
It's typically not a good idea to lubricate the threads that often, if at all. When you do you can't just use regular WD-40, anti-seeze, etc.
And if you do lubricate the threads, shouldn't you be adjusting your torque spec to a higher setting? 996 uses lug bolts. I would guess they're steel. For track days, sometimes different clubs want 100 ft/lbs on lugnuts, I would say the same for lug bolts but can't say for sure. Also a good idea to check the calibration of your torque wrench every few years with a known accurate one. Take care! |
Racer
Scott |
Actually I lubricate my lug nuts WITH anti-seize. Don't need a lot, just so they have a bit on when threaded. If there's some already there, you don't need more.
However, checking torque wrench accuracy is something I recommend. Take care, |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Lug nuts.
Also, use Saran Wrap between the socket & the lug nuts to prevent scratching. Merry X-Mas to all....... Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
To avoid possible confusion, not all anti-seize is created equal! My shop never used silver/gray anti-seize. We only used Lubro Moly LM 508 Anti Seize Compound. We simply referred to it as Copper Paste, and applied it to every clean lug nut stud (male threads only). It does not affect torque, rather, it insures accurate torquing. Put a thin smear on about the end 10mms of thread and assemble. Torque to 96 lb/ft, or to 94 for earlier models; you will be surprised at how easy the nuts/bolts will be to remove next time the wheels come off!
Keep the Shiny Side UP! Pete Z. Last edited by Peter Zimmermann; 12-04-2013 at 11:51 AM.. |
I am confused. Mr. Weiner has always advised me to use anti-seize (copper based only) only on the shoulders of the lug nuts to prevent them from bonding to the wheels and to leave the threads dry. I find this troubling as you are both highly rated in my book and with this conflicting advise, I am confused.
Racer
+ 1
I never use Copper based pastes on Aluminium Wheel Nuts. Porsche recommend OPTIMOLY TA but I have found this difficult to find so I use a Loctite Silver Anti Seize. Buy 235092 Loctite Silver Anti-Seize Lubricants from UseEnco |
Vintage Motorsport
Keep in mind that technically a bolt is a spring. Most wheel bolts get stretched from people who install the nuts with an air gun. Once the bolt is stretched it's junk. It's like a spring that's been stretched too far. It will never return to it's original shape.
Here's an article I wrote for Vintage Motorsport magazine. It's in 2 parts. Richard Newton Last edited by RichardNew; 12-05-2013 at 04:07 AM.. Reason: sp |
Racer
Absolutely. Torque specs are designed with that in mind to allow stretch within the elastic limit, but not beyond it. It's that stretch that applies pressure to the threads that keeps the nut/bolt tight.
I use exactly what Pete Z shows (very, very minimally) and make application of the spec'd torque within the books,..at 96 ft-lbs. on the 89 Carrera.
Always, this way. Never a problem. BEST! Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Max Sluiter
You can stretch something beyond yield and still use it. The urban legend (not sure if true or not) is that the Porsche rod bolts and flywheel bolts would preload beyond yield during installation. Though reusing those is not recommended.
When you have a lower grade steel and stress it beyond yield but below ultimate it will work harden and become more brittle, but you can still load it up to the same point again (generally) and it will be ok, and it won't stretch any more because work hardening increases yield strength and decreases ultimate (brittle). Springs are often "preset" which means they are stretched/crushed beyond yield in order to increase yield strength so that they can endure higher loads during service. This is done by the manufacturer and you need to account for it when winding the wire so you get the correct dimensions afterwards. Torsion bars are also "scragged", hence the left and right markings since you don't want to reverse the strain direction when you have yielded it in one direction.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance Last edited by Flieger; 12-27-2013 at 04:40 PM.. |
