Help Identifying Plug
Hi Everyone,
I was cleaning the carpet, when I found a plug underneath the drivers seat that was not plugged into anything. Anyone know where it goes? From a 86.
Old 05-13-2011, 11:39 PM
BMWDavid's Avatar
I was wondering that as well. Saw that plug a while ago under my seat.
'89 3.2 Carrera Coupe-Silver Anniversary-sold
'06 GTI/DSG
Old 05-14-2011, 02:33 AM
You may want to have your car tented. :-)
Old 05-14-2011, 07:56 AM
vracer's Avatar
They were still putting the same plug in cars in '89. (That is for information only; someone else will have to answer the question. I hope.)
Richard
1989 Venetian Blue Targa
Old 05-14-2011, 08:59 AM
Hendog's Avatar
Now I see why you were cleaning the carpets
As for the plug, I have the same one going nowhere...
Henri
Owned for 21 years: '87 Carrera coupe Venetian blue
Old 05-14-2011, 09:24 AM
passenger side electrical seat power?
Old 05-14-2011, 12:42 PM
vracer's Avatar
Nope. My seats are electric everything, except heated.
Richard
Old 05-14-2011, 06:05 PM
pete3799's Avatar
Seat belt buzzer?
Just a guess.
Pete
79 911SC RoW
Old 05-14-2011, 06:40 PM
fat cab's Avatar
find the other end you get 37.5 more horse power
Old 05-14-2011, 06:46 PM
muck-raker
kidrock's Avatar
It's an electronic worm-zapper. It's supposed to be unplugged, it fools the worms. It looks like it's working perfectly.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 05-14-2011, 09:11 PM
Seat heater?
Old 05-15-2011, 12:02 AM
jmod's Avatar
What are the colors of the wires going to the connector?
Being under the drivers seat could be something to do with the DME. Altitude correction unit?
Old 05-15-2011, 04:54 AM
BMWDavid's Avatar
Well I looked around again and found the other plug that goes into this. I plugged mine together but don't notice anything.
I bet it has something to do with the seat belts...
'06 GTI/DSG
Old 05-15-2011, 06:32 AM
do you happen to know where the other end of the plug was?
Old 05-15-2011, 09:13 PM
BMWDavid's Avatar
It was near the seat...both plug ends were under the carpet.
'06 GTI/DSG
Old 05-16-2011, 02:19 AM
vince_wa
seat belt indicator plug - other end plugs into seat belt harness - my guess
Old 05-16-2011, 06:09 AM
Recreational User
porschenut's Avatar
That's the connector for the inside temperature sensor mounted on the dash, just to the left of the climate controls. It plugs into the heater control box between the seats. You can see it here clearly in the picture:
Old 05-16-2011, 06:47 AM
Porschenut,
Thanks so much! Exactly what I was looking for.
Old 05-16-2011, 12:37 PM
BMWDavid's Avatar
Not on my car...I don't have the temp sensor as I have the manual heat system. Perhaps on my car it does have something to do with the seat belt indicator.
Since my dash lamp cluster is not working I can't see if it is the seat belt warning.
'06 GTI/DSG
Old 05-16-2011, 05:39 PM
Hendog's Avatar
Not on mine
I believe Porsche might have run the wires wether required or not for the sake of efficiency at the factory. Those cars which required it got it plugged into the circuit board, those that didn't, well, didn't. I have the plug, but like many others, it's not plugged into anything. Keep in mind, in the days of the Carrera (mid-late 80's ) Porsche was pumping out a lot of cars, relatively speaking, to the yuppies. Porsche probably (conjecture) tried to streamline production by wiring all the cars the same and then just plugging in the options that were ordered.
I don't have climate control, therefore the cirlced portion on the dash is not populated with the sensor. Also note my control between the seats only goes up to 3. I believe the climate controlled cars have detents up to 10 (I may be wrong on this).
Henri
Old 05-16-2011, 06:30 PM
