Member 911 Anonymous
Question, does the Headlight Relays go before and after the fuse?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Spiderman
With Daniels kit, you don't touch the old wiring. You take two dedicated 12 ga. lines off the battery, one to each relay. One high, one low beam. Each is fused 25 amp. I took a couple of wimpy 16 ga wires off the fuse connections over to my relays to operate them. There are 4 fuses, you only need a single wire from one of the hi and lo beams to operate the relays.
The two white wires going from the bottom and heading to the right.![]() I put the two relays right above the washer pump and condenser fan. Used all 12 ga wire, probably overkill but Dan "recommended it". 14 would have pulled easier through all the existing grommets.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
Spiderman
I'm hoping that "after" is on the bottom but probably no longer matters since the current draw is now "much" less if it was ever much to begin with. The old H5 plugs are just hanging in the buckets now.
