KTL KTL is online now
Schleprock
KTL's Avatar
Front Boge "Insert" Guts
Here's a picture of the "inserts" from the front Boge strut which uses the strut housing tube as the shock absorber casing. No sealed insert here. Just in case somebody was curious, now he'll know what to expect.
This setup gets a little messy when you're replacing your inserts, as I was not expecting so much oil (maybe a 1/2 quart total for both struts) to be in the housing. I only expected a little oil! It was everywhere. Have a drain pan handy. I didn't. Just a measly shop rag.
Bilstein HD green replacement inserts go right in with NO problems.
Kevin L
'86 Carrera "Larry"
Old 02-26-2002, 02:05 PM
Eric Coffey's Avatar
Question
Hmmm. Are you sure those are stock 1987 Boge's? All the Boge's on the later (`87+) cars I have seen had sealed gas (Bilstein, Sachs, etc.) cartridge-type inserts. I thought the oil-filled tubes were used on the earlier struts. Someone please enlighten me.
Old 02-26-2002, 03:08 PM
I had exactly the same inserts as shown in the picture in my stock Boge's on my 89 Targa. It took one old cotton T-Shirt for each side to soak up the oil. Nice and green...
Harold
89 911 Targa, 96 Saab 900S, 02 Passat 1.8T Wagon
02 BMW 530i, 08 Cayman, 17 GTI DSG
19 Subaru Forester
Old 02-26-2002, 04:20 PM
Schleprock
KTL's Avatar
Yep, those are the original Boge parts. Period correct Porsche part number stamped right there on the tubes.
Kevin L
'86 Carrera "Larry"
Old 02-26-2002, 04:24 PM
