-   -   3.6 Engine - What should I do to it before plugging it in (http://forums.pelicanparts.com/porsche-911-technical-forum/610208-3-6-engine-what-should-i-do-before-plugging.html)
Tom '74 911 05-31-2011 01:35 PM
Originally Posted by JeremyD (Post 6053169)
I'm thinking of going ahead with the 964 throttle cable and modifying it.
SO anybody have a picture of a DME box installed under the seat?
I still think I am missing a 2nd connector for the fuel pump relay.
Hi Jeremy -
I ended up cutting off about 12" of the cable housing to make a 964 throttle cable work for me. The gas pedal is now smooth as silk!
Because my seats are lowered, I couldn't mount my DME underneath. I chose the passenger rear seat & had to come up w/some creative wiring harness routing - not the end of the world, but not the most aesthetically pleasing either.
The Patrick wiring harness (which I used) does away with the fuel pump relay - which is nice because my pump now only runs when the engine is running. It always made me nervous that my pump would run w/the key in the 'on' position for obvious accident scenarios.
Your wiring harness looks complete from here, but you will still need to either buy or fabricate additional harness parts/pieces/wiring that connect to both the 14 pin and 6 pin connectors at the DME end of the 964 harness. This essentially connects the DME to the fuel pump, tach, another gauge or two (I can't remember which ones), power for the DME etc... The Patrick harness was a mostly plug & play way to go for me. You can go to their website & download the directions to get an idea of what's entailed.
An aside - I finally drove my car 'around the block' for the first time this past weekend! It didn't catch fire and everything mostly worked. I am having idle issues - in that it won't idle almost at all. I've got a new chip coming that should help, but am also doing some basic diagnosis stuff to see if there are other issues etc... It was nice to drive even 1 mile though!
Tom
JeremyD 05-31-2011 03:12 PM
Thanks Tom. I am also going with the Patrick harness.
Check you cylinder head temp connection. That can give you idle issues. Especially when cold.
CabMike 05-31-2011 07:05 PM
Tom,
I assume you put the patrick throttle cable in after the engine was in the car. Was this a difficult job? I have the Timmins set up, it is working but I would like to switch at some point in the future as I've heard the patrick verison is much smoother to operate.
Thanks,
Mike
JeremyD 05-31-2011 07:31 PM
So cruise control off http://forums.pelicanparts.com/uploa...1306894918.jpg
Fuel lines off to go to Amazon - and try to come up with a non porsche solution to the S pipe... http://forums.pelicanparts.com/uploa...1306895015.jpg
Any problem mounting a oil breather tank here? on the side wall of the engine compartment??http://forums.pelicanparts.com/uploa...1306895085.jpg
The engine is already looking less clutteredhttp://forums.pelicanparts.com/uploa...1306895136.jpg
Tom some additional pictures - (which you probably don't need now.
http://forums.pelicanparts.com/uploa...1306895295.jpg
http://forums.pelicanparts.com/uploa...1306895377.jpg
Tom '74 911 05-31-2011 08:17 PM
Originally Posted by CabMike (Post 6054263)
Tom,
Thanks,
Mike
Hi Mike -
I didn't use the Patrick throttle cable, but I did adapt a 964 throttle cable to work. This was about $150 cheaper in addition to the fact that despite having bought some conversion pieces from Patrick, I could not get them to answer questions or return repeated requests for information - so I gave up and made my own.
I did install it after the engine was in the car - not too bad an ordeal. The toughest part was running some plastic tubing that I used as conduit for the cable through the tunnel first. Once that was in, sliding the cable in and out during the adjustment/fitting process was easy. All in all, not too bad (I do have a scissor lift though which does make things under the car a lot easier!).
Tom
Tom '74 911 05-31-2011 08:21 PM
Jeremy -
I've seen photos of a lot of catch cans mounted in the corner you posted a photo of. I chose to mount mine on the motor on the other side:
http://forums.pelicanparts.com/uploa...1306898452.jpg
JeremyD 06-01-2011 06:07 AM
a handy reference picture I found. Not a whole lot new - but worth it for the reference
http://farm1.static.flickr.com/95/22...fc1e4792_b.jpg
KTL 06-01-2011 06:53 AM
Put the catch where ever it's most convenient. There's nothing super critical about its location.
I mounted my catch on the 3.2 where the A/C compressor used to be located. The intake had some places where I could connect my home made brackets. I fastened the catch to one of the fuel rail fasteners and I think an empty threaded hole on the intake runner.
On my '79, the catch is in the LR wheel well. A hose runs from the oil tank all the way across the engine bay roof and then thru the wall fwd of where the fuse/elec. panel lies.
JeremyD 06-02-2011 09:56 AM
just trying to economize and limit the crossing of lines from one side to another... Since I don't have a charcoal canister I may look at ways that I can vent some of these vacuum lines too. Don't want them sucking raw air into the intake...
Tom '74 911 06-02-2011 10:13 AM
Jeremy -
I know our intakes are a bit different, but I ended up plugging the lines labeled in the photos below including the one to the charcoal canister (#4). Basically, you want all the intake air coming through the barn door (filter) and none coming through the various vent lines etc... You probably know this already (I didn't!). I posted a thread asking about what lines to plug and didn't get any hits, but I called the guy I sourced my motor from (William Knight) and that's what he said to do.
As an aside, I did a little Italian tune up on my car yesterday and it's running great. The idle has improved and it seems to be running strong. I did some trouble shooting previously and found nothing glaringly wrong or out of sorts, so I just drove it and it all seems to be good at the moment.
Tom
http://forums.pelicanparts.com/uploa...1307034737.jpg
http://forums.pelicanparts.com/uploa...1307034760.jpg
http://forums.pelicanparts.com/uploa...1307034774.jpg
KTL 06-02-2011 10:29 AM
Yep. What Tom said- plug 'em.
For instance in Tom's pictures, #3 is the one you must plug when you install your oil tank catch can. #4 is the brake boost vaccuum assist, and of course your '74 doesn't have boosted brakes.
Charcoal cannister hookups on the engine can be plugged too. That's what I did on my 3.2 when I removed it and had no problems. My understanding is the charcoal can is a vent for the fuel tank and those fumes are plumbed through the charcoal can and then plumbed to the air filter housing. If you put a cone filter on there, no opportunity to reconnect that charcoal can line
JeremyD 06-04-2011 06:02 PM
I got the Alternator off - and underneath looked like it had an oil leak for 40,000 miles - or the outside of one of BP's oil rigs.
http://forums.pelicanparts.com/uploa...1307235232.jpg
so decided to bite the bullet and pull the intake.
Couple of gaskets - what the he!!
http://forums.pelicanparts.com/uploa...1307235383.jpg
Finished - oh my
http://forums.pelicanparts.com/uploa...1307235614.jpg
http://forums.pelicanparts.com/uploa...1307235633.jpg
http://forums.pelicanparts.com/uploa...1307235643.jpg
Aw well - I planned on replacing all the O rings anyway - and the breather cover gasket - so at least I'll start with a cleaner engine (and no PS pump leaking)
Here it is now... good base to build off
http://forums.pelicanparts.com/uploa...1307235747.jpg
http://forums.pelicanparts.com/uploa...1307235762.jpg
The good thing is that it looks like it's had a fairly recent top end. The valves and valve guides looked really good and fresh.
JeremyD 06-07-2011 12:47 PM
Fuel lines and S hose firesleeved finished from Amazon.
Got my first shipment from Pelican too so I can start my O ring/seal replacements... Got more MAP gas too - out of 12 exhaust studs - 7 gave up without much of a fight - the others are soaking in PB blaster and will get gassed until they are cherry red and submit!.
http://forums.pelicanparts.com/uploa...1307476060.jpg
LJ851 06-07-2011 12:54 PM
Nice progress. Check out a penetrating oil called Kroil. Its similar to PB Blaster but works better.Amazing stuff.
JeremyD 06-07-2011 06:45 PM
all exhaust studs off - woo woo - no drama!
really not too bad.
http://forums.pelicanparts.com/uploa...1307497298.jpg
test fit my B & B headers (Thanks Ed)- wonder how hard it is to cut off the heater boxes
http://forums.pelicanparts.com/uploa...1307497356.jpg
These are for ShakinJoe - hey - check out this fit! (this is a BMW Exhaust he found... :D:D:D
http://forums.pelicanparts.com/uploa...1307497437.jpg
http://forums.pelicanparts.com/uploa...1307497486.jpg
A little work - but I planned on that anyway.http://forums.pelicanparts.com/uploa...1307497524.jpg
KTL 06-09-2011 10:16 AM
Good call cutting off the heater boxes if you don't need them. Losing the boxes will definitely make installation of the headers a lot easier.
175K911 06-09-2011 10:26 AM
Hey Jeremy, you're that far apart, have you checked the distributor drive belt yet?
JeremyD 06-09-2011 12:03 PM
I looked at it - and it looks good - but how else do you know??
KTL 06-09-2011 02:37 PM
Just like the fan belt, if you push on it and cracks open up then it should be replaced. Should have a reasonable amount of tension on it.
Joe Bob 06-09-2011 03:43 PM
When my 915 ate a gear, I bought a gasket kit from Pelican and replaced everything I could on the top end. The kit while not cheap is more economical than buying the parts individually.
I used "Purple Stuff" from Kragen to degrease. Spray pump bottles, a wire brush and a pressure washer. 50/50 with water mix.
Pull the clutch disc the stuff will weld the disc to the flywheel. Drain and rinse the spray bottles or it will eat the plastic pump mechanism.
Consider a WEVO trans upgrade for the intermediate plate.
0396 06-09-2011 06:23 PM
Nice :)
JeremyD 06-10-2011 07:06 AM
Got the valve covers off last night
Checked and adjusted valves last night - only two needed any adjustment - the rest were good to go.
Stuff off to powder coater this morning.
JeremyD 06-15-2011 08:31 AM
I decided to replace it since I was this far along.... and the o ring. I'll be disappointed if this thing leaks - new seals all around...
Joe Bob 06-15-2011 08:35 AM
I would also consider the single alternator belt conversion.
JeremyD 06-15-2011 08:42 AM
yep - doing the single alternator belt conversion too
JeremyD 06-17-2011 08:02 AM
Flywheel seal replaced. http://forums.pelicanparts.com/uploa...1308322767.jpg
O rings and gaskets replaced. Looks like they had a leak on where the oil thermostat usually goes - there was some type of sealent there kinda gooped on.http://forums.pelicanparts.com/uploa...1308322830.jpg
Crank pulley replaced - with Patrick Version http://forums.pelicanparts.com/uploa...1308322892.jpg
So I can run the earlier cross member and sheet metal.
Injectors back from getting cleaned (they were in good shape - but good insurance) distributor off to get the belt replaced. Again - good insurance.
KTL 06-17-2011 08:43 AM
Looking good JD. Q-tips, rubber glove finger, cellophane plastic, masking tape, paint swabs on potential loose fasteners....... You're worse than me! :D
PcarPhil 06-17-2011 11:53 AM
Jeremy,
Can you measure the diameter of the PMS crank pulley and the diameter of the stock inner pulley and let us know what the dimensions are? I'm pretty sure the PMS pulley has a smaller diameter vs. the stock pulley.
I went with the Rothsport pulley because it's diameter is the same as stock and I didn't want to slow the fan down by going to a smaller diameter lower pulley.
Please let me know. Thanks!
Joe Bob 06-17-2011 11:59 AM
I'm a known PMS hater, bought the PP version. It has ALWAYS required a blip of the throttle to turn the alt light off at start up. So it's a bit of an underdrive. Doesn't do a thing to the idle.
Tom '74 911 06-17-2011 12:24 PM
I have the PMS version too and like Joe Bob, my alt. light comes on at startup and won't go off until I get the rpms over 2K or so with a blip. Once off though, it stays off even at idle speeds. I've been told that the stock ratio pulleys are not as efficient at higher rpms and cause more drag (ie:lost power) - folklore? dunno. I wish I had a spare wad of cash and a dyno in my garage so I could try all sorts of combinations of pulleys, exhausts, mufflers, engine components etc... Maybe in my next life.
One thing I did have trouble with is getting the PMS pulley on square. I noticed it wobbling quite a bit when checking the oil level when I finally got my car running. I got a few tips from PMS about the install - namely to make sure the pin sits flush w/the outside face of the pulley and to use just a tad of antiseize during the install to allow it to slide on in an even manner. I don't know if the 993 pulley is different than the 964 pulley, which is a tapered fit etc...
I have mixed feelings about PMS. I used a few of their products on my engine conversion, but went elsewhere for other bits as I had a heck of a time getting them to return repeated calls and emails w/questions about product support etc...
Joe Bob 06-17-2011 01:45 PM
That's the least of my issues with PMS....a good attitude goes a long way. Don't get me started on their phone ettiquette. :confused:
PMS, good acronym for those wankers.
JeremyD 06-18-2011 06:16 AM
Originally Posted by Kaefer (Post 6085431)
Jeremy,
it's 96 mm vs 114
Pretty sure Bruce Anderson states in his book that they were able to pick up HP with a smaller crank pulley turning the fan a little slower
DaddyGlenn 06-18-2011 07:39 AM
Originally Posted by JeremyD (Post 6086666)
it's 96 mm vs 114
Very old school... Back in the day we'd put a "power pulley" on our VW bugs for the same effect. Turns the fan at a slower rate which basically reduced the hp lost to turning the fan. Down side is the fan turns slower which reduces the cfm over the engine. This could be bad if environmental factors and tight original engerining tolerances conspire against you. Might not be a big deal on these motors. But it was a concern on a built up bug motor.
JeremyD 06-18-2011 08:28 AM
Hey Tom - is the 10 x 750 fan belt the same one used on the 996 turbos? (which is listed as 10 x 753)
JeremyD 06-21-2011 01:20 PM
modified the heater fan duct just need to paint it
http://forums.pelicanparts.com/uploa...1308687182.jpg
http://forums.pelicanparts.com/uploa...1308687375.jpg
175K911 06-21-2011 01:25 PM
Don't you need the fitting to blow air into the distributors?
JeremyD 06-21-2011 01:29 PM
I'll drill and plumb once I get it painted.
175K911 06-21-2011 01:31 PM
I figured you would know that, but wanted to be sure. Gonna be a fun toy when it's all done.
DW SD 06-21-2011 01:38 PM
I have the PMS crank pulley and do not have the need to blip the throttle to energize the alternator. I have a '95 fan, intake and alternator. Maybe that is why?
I also ended up using an 11mm wide fan belt. It fit the pulleys fine and seemed a bit more robust when I was selecting it. At the local NAPA, they have every conceivable type and size of belt, it seems.
Doug
chaw704352 06-21-2011 07:21 PM
Good luck. That is a clean looking engine. I am still planning on doing a 3.6 myself. I look forward to following your install.
