-   -   3.6 Engine - What should I do to it before plugging it in (http://forums.pelicanparts.com/porsche-911-technical-forum/610208-3-6-engine-what-should-i-do-before-plugging.html)
JeremyD 09-12-2011 06:25 AM
Originally Posted by DW SD (Post 6249332)
Remember, like the 3.2, the computer turns on stage 2 of the DME relay which energizes the fuel pump. It has to see crank movement, first. Lots of times the crank position sensor isn't adjusted properly.
Are you getting spark? If you are getting spark, the DME is seeing the crank move.
Buy, if you don't have one, the fuel injector test light. I think they are called noids.
Hopefully, is something simple. I'm sure it is.
Good luck!
Doug
Thanks Doug - so I have stage one with the DME relay clicking - I'm guessing that the flywheel needs to be seen for the 2nd stage to kick in and the fuel pump to be energized. Obviously don't have that yet.
at least it has gas and oil in it - that's a big step... :)
PcarPhil 09-12-2011 06:30 AM
Originally Posted by JeremyD (Post 6249595)
OK - Thanks Scott - I was trying to get into my head how the starter was energized without connecting to the wiring harness of the chassis. from the key side - how does the system know to start the starter? I also need to check that I have 12 volts on the coils too.
I'll PM you my phone number thanks for the offer. But the more I'm thinking about it - there's probably some bridges that I need to make with the chassis harness.
On my '77 I had to move a few pins around on the chassis 14 pin connector when I installed my 3.2. When I installed the 3.6 (again from memory) I don't believe I had to make any additional wiring changes with the chassis connector. The 964 engine was similar to the 3.2 in that regard.
So yes I believe you'll have to move a few pins in your 14 pin '74 chassis connector. Alternately you could make a jumper conversion cable between the chassis connector and "extra" engine 14 pin connector.
I suggest getting the pin out diagram for your '74 connector and the pin out diagram for your 964 engine. Adjust pins as necessary. Once your wires are straight your starter should start crankin'!
When you turn the key - with the PMS harness and the 964 DME harness installed - once the DME sees the engine spinning at a certain RPM from the starter it'll send signals for fuel and spark.
DW SD 09-12-2011 06:40 AM
I think the starter relay is a yellow lead on the 14 pin connector.
Use a test light and a friend to find which lead at the 14 pin connector (chassis side) lights up with the starter position on the key. From there find the lead on the engine side which you've attached to the starter relay.
Another common problem is to wire the DME computer off from a terminal at the fuse box which turns off under start. IE the radio turns off under start, probably headlights, too. The DME will have power, except under cranking. Make sure you don't do that. This problem has been highlighted in many threads.
When I think back to my install, I bought a new 14 pin connector, dissassembled the chassis side and moved many of the pins, checking each one with its partner on the engine side. I think several ended up in different positions.
Engine sensors like temp, alternator energizer, of course, starter relay are all on that 14 pin connector. Others, disabled are also on there (I think), are the heater blower motor.
Doug
PcarPhil 09-12-2011 06:57 AM
My '77 chassis 14 pin connector currently only uses the following pins with my '91 3.6 engine:
1, 5, 9, 11, 4, 6
Here's a pinout pic of an '81 connector to be attached to a '91 engine:
http://forums.pelicanparts.com/uploa...1315835450.jpg
My 14 pin connectors. One goes to the DME harness the other goes to the chassis harness:
http://forums.pelicanparts.com/uploa...1315835506.jpg
http://forums.pelicanparts.com/uploa...1315835792.jpg
DW SD 09-12-2011 07:20 AM
Notice, I had some trouble getting the pins correct. :D I think the photo shows the engine connector. Like Scott, I only used 5 (or six) of the pins.
Printout:
http://forums.pelicanparts.com/uploa...1315837044.jpg
Testing process:
http://forums.pelicanparts.com/uploa...1315837156.jpg
Tom '74 911 09-12-2011 07:21 AM
Doug
Jeremy -
I made the mistake Doug mentions in the first quoted paragraph. It took me a few frustrating days of troubleshooting to find it. I posted a thread on it too.
I also bought a new 14 Pin connector and rewired the chassis side to mate w/the engine side cleanly. I spent some time w/wiring diagrams from '74 & '90 and a multi meter to make sure everything was where it should be. I'm assuming you have the wiring diagram for the Patrick conversion harness too which is pretty easy to follow (except one wire - see first paragraph!)
You're getting good advice from Doug & Scott here - they covered everything I was going to suggest.
Tom
JeremyD 09-12-2011 07:34 AM
Originally Posted by Tom '74 911 (Post 6249728)
Jeremy -
I saw that last night - where did you end up putting that wire? I went with my sunroof fuse - because I don't have a sunroof - but now I'm worried that it also may switch off during cranking.
Alright I have some ammo now... Silly of me to assume that buying a 3.6 conversion harness meant that it was all I needed...
DW SD 09-12-2011 07:44 AM
whip out a friend and your test light. I want to say fuse #6, but that's a wild ass guess from five years ago.
Crank at the key and make sure you still have power to the DME at the fuse panel under crank. If not, move to an open one that does.
If you see the above photos of my 14 pin connector, I'm almost certain yellow is the starter relay. You'll notice it is of larger gauge than those feeding sensors like temp and oil pressure.
Doug
Tom '74 911 09-12-2011 07:46 AM
I went to the next fuse past the sunroof fuse (#6 I think). I had my wife crank the motor while I used my voltmeter at the fuse box to verify that the fuse had 12V while cranking.
Tom
Tom '74 911 09-12-2011 07:47 AM
Doug is quicker than me! At least we're telling you the same thing!!!
JeremyD 09-12-2011 08:31 AM
Thanks - I'm feeling a little better about this.
KTL 09-12-2011 09:51 AM
I'll just reinforce the pin switching for fun. When I worked on a 3.2 going back into a '78 (because we had a 3.6 coming out of a '78 going into an '88 3.2), we had to move pins on the 14 pin harness. I remember vividly that Timmon's instructions saying the red #2 needed to be moved or disconnected or something, otherwise it would "backfeed" the system. Well the eager goofball named einreb who can't read directons just hooked up the 14 pin and turned the key to see what would happen. A ground wire behind the instrument panel decided to release it's magic smoke..... :D
Definitely make sure you've got all the wires going where they should be, before hooking up the battery and keying her on!
JeremyD 09-12-2011 10:39 AM
helpful post here
Originally Posted by tholyoak (Post 832480)
Joe
Here are some pictures that will hopefully help you
You should have a total of 3 wiring harnesses for the 964 engine as stated above
1) The engine should have a harness on it for the various sensors, as well as a long pigtail with connections for the starter and reverse light switch, it terminates near the fuse panel in the engine bay with these two connectors
http://forums.pelicanparts.com/uploa... 002_small.jpg
The large 12 pin connector will mate with the DME harness coming from under the drivers seat which we will see in a minute.
The small 14 pin connector will mate with the 14 pin connector on your relay panel on the chassis
http://forums.pelicanparts.com/uploa... 003_small.jpg
This it the connection you will have to check for compatibility as some of the pin outs are not compatible between the chassis and the motor, you will need to check what the pin out on your chasiss is on a site like marcesq has above
The pinout for the engine side of the 14 pin connector is
1 yellow;starter
2 not used, disconnect
3 not used
4 gn/red; oil pressure gauge
5 gn/ye; reverse light switch
6 gn/br; reverse light switch
7 bl/gn; heater fan, not needed
8 br/bl; heater fan, control signal
9 gn/wht; oil pressure warning light
10 re; relay blower motor, not needed
11 bl; alarm, not needed
12 re; a/c compressor
13 ye/gn; relay blower motor
14 re; relay fuse panel heater blower motor
The other harness is the DME harness as shown below
http://forums.pelicanparts.com/uploa... 001_small.jpg
At the center of the picture is the large 12 pin connector that connects to the mate coming off the engine shown above
The rest of the connectors mate to the motor sensors.
At the top of the picture is the large DME connector which connects to the brain, and 2 smaller connectors a 6 pin and a 14 pin, these will interface with a homemade wiring harness shown below
This is the one I made
http://forums.pelicanparts.com/uploa... 004_small.jpg
At the center is three connectors
A 14 pin and 6 pin to mate to the connectors above by the large DME connector, and another 6 pin connector that holds the DME relay. Several wires extend from this harness to the battery, the fuel pump, fuse panel, switched ignition, oil temp gauge, check engine light, fan belt breakage light etc, Ingo has a nice shematic on his site.
Hope this helps you and others. The interface harness is really quite simple to make, but then I have also done 2 of these swaps now.
Let me know if you need more help
Todd
holyoak@brandeis.edu
JeremyD 09-12-2011 05:39 PM
success - I used the fuse for the air blower - heated rear window - that doesn't go "dead" on crank.
woo woo - I'm a happy camper now.
DW SD 09-12-2011 05:52 PM
that was simple :D
when do you fire it up for the first time?
You can double check your gauge connections by either grounding the gauge wire at the engine or using a rheostat and checking gauge sweep (at least for oil pressure and temp).
Doug
JeremyD 09-12-2011 06:04 PM
about 15 minutes ago
DW SD 09-12-2011 06:08 PM
how's it sound? Any test drives in the near future?
Doug
JeremyD 09-12-2011 07:03 PM
Doug
pretty good
3.6 fire up for the first times - YouTube
ShakinJoe 09-12-2011 07:16 PM
Awesome!
DW SD 09-12-2011 08:07 PM
I like it! Congrats
Doug
jpnovak 09-12-2011 08:41 PM
Very Cool. nothing like the first fire of a motor when building a new project.
JeremyD 09-12-2011 09:08 PM
Hey - my alternator is not working - not showing a charge - do I have to get the single pulley conversion for the upper fan too? just bought the lower single pulley
I have this - http://www.patrickmotorsports.com/im...CRPUEA-18k.jpg
do I need this to make sure my alternator works?? V Looks like just the fan is spinning now...
Patrick Motorsports - PMP 36FAN-HUB FAN DRIVE HUB ENGINE CONVERSION 3.6L 3.8L RS RSR ALTERNATOR SINGLE BELT DRIVE PULLEY PORSCHE 911
cudabnu 09-13-2011 07:38 AM
Single or dual pulley doesn't matter on the charge, did you take a volt meter and confirm the no charge? I don't remember doing anything special for the Alt when I did my 3.6 conversion.
oops, I see since you did the single lower pully change, then yes you do need the single upper conversion.
Tom '74 911 09-13-2011 07:39 AM
Oh the glorious sound of an engine's first start!!!!
I have a Patrick crank pulley and a Rothsport fan pulley - not sure why I ended up w/that combo but anyway. . . My alternator light on the dash/gauge comes on when I first start it up. As soon as I rev it past 2K, it goes out for good.
Per KTL's post above - when I first wired everything up, I had that issue w/the red wires at the 14 Pin connector. I didn't disconnect them and back fed the system. My gauges and lights were all funky. Fortunately, there was no apparent damage and when I finally disconnected them, it was all good.
Tom
SAY - 642 09-13-2011 08:10 AM
Awesome, Jeremy....beautiful sights & sounds!
IanTBoyd 09-13-2011 09:49 AM
My 3.6 conversion does the same thing, the light stays on until the car has hit 2k rpm once and then it is out til I start the car again.
JeremyD 09-13-2011 10:09 AM
Per Patrickmotorsports - you need the top hub (that they sell, obviously) with the single pulley lower - to keep the shaft stable = otherwise the fan moves - but the alternator does not {because the fan is on a bearing that slides onto the alternator shaft}
I knew it wasn't charging because #1 I have a voltage gauge in place of the oil level gauge - and #2 I have a voltage determined red led light on my dash that signals anything under 12 volts (which would indicate a broken belt and a no charge situation)
JeremyD 09-13-2011 10:13 AM
and yes, I try and follow KTL's advice - and made sure I disconnected the red #2 wire so I didn't get feedback. In fact - I pulled all the lines off that I didn't use and capped them off - I'm surprised my car ran to tell you the truth with the 2.7 - the T30 14 prong plug was pretty corroded. now all updated with marine grade wiring and heat shrink. I may look for a 6 prong plug that I can connect and disconnect easily - just used 6 bullet connections from harness to harness.
JeremyD 09-28-2011 07:07 AM
Couple of resources for the engine pin / chassis harness for those that follow this course in the future
http://forums.pelicanparts.com/porsche-911-technical-forum/613825-help-please-another-1973-3-2l-implant.html
http://forums.pelicanparts.com/uploa...1308182597.jpg
Yes you do need both the top and bottom pulleys to make the alternator work.
Patrick has good stuff - but their customer service blows.
Check out rothsport - good stuff.
The conversion is not really too bad - it's all the supporting stuff that makes it a pain in the butt (and takes up alot of time) probably set me back 2-3 weeks messing with the fuel line upgrades and moving the pump (but len cummings makes replacement fittings and lines - good stuff)
Wiring is another - probably could have cobbeled together something - but no - everything has to be marine grade, heat shrunk, etc...
Third thing is the transmission - changing from the mag case - to a carrera 915 - with a cooler - LSD - etc. change drive shafts and then adding some WEVO bits - added to the expense - and the time.
Hopefully it will all be worth it in the long run...
arrivederci 09-28-2011 07:16 AM
This might belong in another thread...but what 915 strengthening options can be made to work with the factory euro trans cooler? I have one from an '84 and also have the 108mm flanges. But nothing else had been done to beef up the 915.
JeremyD 09-28-2011 07:36 AM
If you open it up - put the one piece bearing retainer.
Without opening it up - put provisions for a cooler and at least the side plate. The billet side plate uses (typically depending on mfg) 930 bearings (which a much meatier than the 911 varient)
You want to stop the side from deflecting under acceleration. Also adding a LSD can help too - but it adds a little heat ~ 10 -20 degrees was quoted to me.
Sooooooo... with my research - and talking to people that are smarter than me = I added a provision for cooling (wevo shift plate pick up and temp sender) wevo side plate - with 930 bearings. AN fitting on top of the differential cover - AND a tilton pump and big a cooler fitted to my decklid.
pump
http://forums.pelicanparts.com/uploa...1315359390.jpg
cooler and lines can be seen here
http://forums.pelicanparts.com/uploa...1316022313.jpg
http://forums.pelicanparts.com/uploa...1317184855.jpg
Wevo goodness
http://forums.pelicanparts.com/uploa...1309186796.jpg
http://forums.pelicanparts.com/uploa...1310052335.jpg
LJ851 09-28-2011 08:05 AM
Those wevo parts sure look nice! It's hard to tell from the pics if the pump is isolated from the body (rubber mounted). I'm going to assume you did but if not you will want to.
ShakinJoe 09-28-2011 08:16 AM
Shame on you for asking this!!! ;)
Jeremy is changing his Avatar to "King of Overkill":D
He actually does everything right, but then just does it better!!!
JeremyD 09-28-2011 08:42 AM
HA HA - sickness really -
JeremyD 10-03-2011 09:13 AM
OK - just to close this out.
The car is back on the road - have a few minor items to sort out - but should be able to knock out in a reasonable amount of time.
From my other thread on the car - more information here; http://forums.pelicanparts.com/porsche-911-technical-forum/529220-well-here-she-30.html
reflecting back - this is a pretty big job. Probably more to do with me stripping the engine down to clean and change some of the seals. Like John said - the 3.6 engines really should be stripped down to the case and resealed. And actually there is quite a bit of truth to this.
There are two spots where it is leaking a little oil - both on the cam covers - the seals that I did not replace - where the covers join at the side of the case. really cause I didn't want to have to re time the cams. Still, I'm glad I changed the seals that I did change. I'll have to live with an odd drip.
In reflection - I really set up the car when I redid last year - suspension wise, brake wise and cooling wise. Even then - I didn't replace the fuel lines and relocate the fuel pump - both turned into bigger jobs as I had to remove a majority of the front suspension to get to them.
Even though I read a fair amount - I was unprepared regarding the engine harness to chassis harness - Figured you buy the conversion harness from Patrick - that's what you need - right?
Also regarding the alternator - if you go with the single pulley conversion - with the early car engine tin and carrier - you still need the single alternator pulley.
Right now I'm still figuring the engine oil temp sender (gauges have early sender, engine has later dual pole) and speedometer - had to convert to later electronic version... of course with no wiring harness.
SO anyway - it's in - and running -
EDIT - ended up running a separate line for the oil thermostat line - the other one kept shorting out and giving false readings. I also changed out the thermostat to an older style - so the pressure no longer reads twice the actual.
Tom '74 911 10-03-2011 09:52 AM
Jeremy -
Congrats on getting it running and back on the road. I'd agree w/you - it is a big job. Lots of little details that add up sucking time & $$.
I converted to an electric speedo too. I ran 2 new wires from the dash, to the rear of the center tunnel where they connect to the speedo sensor wires; stock-like I think. Not too bad to do.
After driving my car all summer, I still have some little things to sort out. It will never end - but then again, what would I do with all the extra free time and money if it did end? : )
Tom
arrivederci 10-03-2011 10:02 AM
Great project and I've been watching all along. I am on a similar path, although my '72 is getting prepped on a rotisserie in my garage before I send it out for paint. I put what I think are the finishing touches on my 3.6 this weekend, bolting up the PMS flywheel, etc. I'm sure I will have some things to do when I start trial fitting the motor / tranny since they will both be new to my chassis...working out the kinks with airbox/air filter clearance, engine mount spacers, factory trans cooler, second fender mount oil cooler, fuel lines, etc etc etc.
Not trivial. But at least you've built a great reference for me and future 3.6 installs. Thanks!
DW SD 10-03-2011 10:57 AM
Don't forget that you knocked out a chunk the project when you added the second oil cooler the previous go-around.
I upgraded to the Hargett cam covers and still get leaks there. those are frustrating to solve. My 3.2 never leaked. The 964 cover design seems a great improvement, yet in practice it doesn't seem to work the way they should (in preventing leaks).
Doug
JeremyD 10-03-2011 11:50 AM
My 3.2 was bone dry - my mag case 2.7 never dropped any oil - but my 964 c2 targa leaked like a sieve - go figure...
quattrorunner 10-13-2011 04:21 PM
Sub for info
