MBruns for President
Got the valve covers off last night
Checked and adjusted valves last night - only two needed any adjustment - the rest were good to go. Stuff off to powder coater this morning.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
I decided to replace it since I was this far along.... and the o ring. I'll be disappointed if this thing leaks - new seals all around...
RETIRED
I would also consider the single alternator belt conversion.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
yep - doing the single alternator belt conversion too
Flywheel seal replaced.
![]() O rings and gaskets replaced. Looks like they had a leak on where the oil thermostat usually goes - there was some type of sealent there kinda gooped on. ![]() Crank pulley replaced - with Patrick Version ![]() So I can run the earlier cross member and sheet metal. Injectors back from getting cleaned (they were in good shape - but good insurance) distributor off to get the belt replaced. Again - good insurance.
Schleprock
Looking good JD. Q-tips, rubber glove finger, cellophane plastic, masking tape, paint swabs on potential loose fasteners....... You're worse than me!
Kevin L '86 Carrera "Larry" |
Can you measure the diameter of the PMS crank pulley and the diameter of the stock inner pulley and let us know what the dimensions are? I'm pretty sure the PMS pulley has a smaller diameter vs. the stock pulley. I went with the Rothsport pulley because it's diameter is the same as stock and I didn't want to slow the fan down by going to a smaller diameter lower pulley. Please let me know. Thanks! |
RETIRED
I'm a known PMS hater, bought the PP version. It has ALWAYS required a blip of the throttle to turn the alt light off at start up. So it's a bit of an underdrive. Doesn't do a thing to the idle.
One thing I did have trouble with is getting the PMS pulley on square. I noticed it wobbling quite a bit when checking the oil level when I finally got my car running. I got a few tips from PMS about the install - namely to make sure the pin sits flush w/the outside face of the pulley and to use just a tad of antiseize during the install to allow it to slide on in an even manner. I don't know if the 993 pulley is different than the 964 pulley, which is a tapered fit etc... I have mixed feelings about PMS. I used a few of their products on my engine conversion, but went elsewhere for other bits as I had a heck of a time getting them to return repeated calls and emails w/questions about product support etc...
'74 911 Red Sunroof Coupe, 3.6L, etc... '76 912 Yellow SPEC 911/911CUP |
RETIRED
![]() PMS, good acronym for those wankers.
Pretty sure Bruce Anderson states in his book that they were able to pick up HP with a smaller crank pulley turning the fan a little slower
Tired Member
Very old school... Back in the day we'd put a "power pulley" on our VW bugs for the same effect. Turns the fan at a slower rate which basically reduced the hp lost to turning the fan. Down side is the fan turns slower which reduces the cfm over the engine. This could be bad if environmental factors and tight original engerining tolerances conspire against you. Might not be a big deal on these motors. But it was a concern on a built up bug motor.
Glenn Daily Driver - '78 911SC RoW Endurance Racer - '85.1 944 Street/Track Project - '86 951 Race Project - 944 Spec |
Hey Tom - is the 10 x 750 fan belt the same one used on the 996 turbos? (which is listed as 10 x 753)
modified the heater fan duct just need to paint it
Don't you need the fitting to blow air into the distributors?
Ed '86 911 Coupe (endless 3.6 transplant finally done!) '14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one) '97 BMW 528i (the sensible car, bought new) '12 Vintage/Millenium 23' v-nose enclosed trailer |
I'll drill and plumb once I get it painted.
I figured you would know that, but wanted to be sure. Gonna be a fun toy when it's all done.
I have the PMS crank pulley and do not have the need to blip the throttle to energize the alternator. I have a '95 fan, intake and alternator. Maybe that is why?
I also ended up using an 11mm wide fan belt. It fit the pulleys fine and seemed a bit more robust when I was selecting it. At the local NAPA, they have every conceivable type and size of belt, it seems. Doug
1971 RSR - interpretation |
Good luck. That is a clean looking engine. I am still planning on doing a 3.6 myself. I look forward to following your install.
