MBruns for President
Hopefully get my powdercoating stuff back so I can start making some progress. at least I'm getting some stuff knocked out on the boat!
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
OK - so it seems that the 964 Tin is easier to modify (for the single pulley conversion and 911 engine carrier) than trying to make the earlier motor tin work.
did that this weekend - got valve covers (and new gaskets) timing chain cover (and new gaskets, tensioners looked good!) ![]() I am doing more - as the in tunnel fuel lines will be replaced - and I'll go ahead and relocated my fuel pump. Not making near the progress that I would like to make -
Ya, I can relate to that!
Don't powder coat/finish the engine tin until you test fit the engine and gearbox in your car. I had to chop down the rear of the 964 rear tin that I used - by quite a bit. Test fit in your car before going too far. . . I can relate to the fact that the process seems to progress far too slowly and take far too long. It's looking really good though! Tom
'74 911 Red Sunroof Coupe, 3.6L, etc... '76 912 Yellow SPEC 911/911CUP |
Hey = actually got intake gaskets and made some progress last night.
starting to finally look like an engine
Jeremy,
did you read my or Kaefer's thread about the Gurney bump in the back window shelf? This was to provide clearance for the intake. Might be worth exploring this, too. Basically, I used a 4x4" and a jack to make more clearance for the intake. cheers, Doug
1971 RSR - interpretation |
I did now. Who knew? Just in the center, right?
I didn't have to do anything to the rear parcel shelf on my '74 to get a 964 engine to fit. The 993 injection could be taller though. . . test fit!!
I forgot about the gurney bump until just recently. I think that creating that bump is important to being able to use the early engine console and crossmember without additional spacers.
What I did is test fit the engine and trans under the car while on jackstands to figure out where the gurney bump needed to be in the shelf. IIRC I used the 4x4 in two spots: 1 in the center and 1 just slightly right of center. The bump may not be 100% necessary but I feel it makes for a better overall 3.6 engine fit.
Thanks Scott
With the 993 engine, I had no choice, except to use spacers and drop the engine down. Still, I used 1/2" spacer between the chassis and the top of the engine cradle. I think the bump gained me about 1".
My bump is above the idle control valve, which is the high point for me. for what it is worth, the bump is also not noticeable once the carpet is laid in the back window deck. Doug
In the process of replacing the in tunnel fuel lines also AND relocating the fuel pump - more fun to come!
Doing the same with the fuel pump, although was cautioned by many about replacing the tunnel fuel lines...at least on a '72. So I was planning to run AN-6 braided lines under the car on the drivers side. Of course I want the cleaner packaging of running factory carrera lines through the tunnel. Decisions. I'm many months away (need to finish rust repair and go to paint before final install).
- '72 911T - '81 911SC Euro |
I'm following Shaun 84 Targa lead on this:
Front and Rear factory metal lines running through the center tunnel flared with fittings. ![]() ![]() ![]() ![]() ![]()
Schleprock
That's a very nice install by Shaun.
I think the extra hassle of steel tubing and flaring is worthwhile. My racecar came with braided stainless hose run through the cabin (cabin area itself, not tunnel) and the car always stunk like fuel. Checked the carbs and made sure they were leak free (whole 'nother story for another thread), replaced some rubber fuel lines in the engine bay since they were old, then decided to tackle the main fuel line. When I removed the main fuel line it was rather crackly if you bent it at a sharp angle. So there's your stinky culprit right there...... Point being is that braided stainless is just like any other rubber hose except it has the metal shield on it to protect it from chaffing. It still ages like other rubber hose, so it doesn't last forever. That said, I replaced my braided hose with new braided and ran it through the tunnel this time. Next time I replace it, i'll use steel tubing run through the tunnel, replacing the old abandoned steel lines that are still present. Thanks for sharing JD. I always learn something good from your projects
Kevin L '86 Carrera "Larry" |
Finished this process - used fittings from Len (BOXSTERGT) Cummings - 3/8 - 10mm fuel lines for both feed and return - 304 stainless steel from McMaster - they were around $30 a piece for 6' sections.
was kind of a biotch to do - but I'm glad it's done. Really glad - as seeing the nylon running through the center tunnel (and passenger compartment) gave a shiver from a safety perspective. ![]() ![]() One is in - this is how the line looks going in ![]() ![]() pain in the neck - but probably the best alternative to the nylon lines that were in there. I also put some regular fuel line over to make sure there was no rattling (although I can not imagine - they are a snug fit.
Fuel filter and accumulator? What are you guys using - just realized my accumulator is like 1/4" input - M10 or M 12??? Should I just get a fuel filter from a 964 and plum
I'm using the 993 filter. I think it is the same as the 3.2L (84 to 89).
There is no accumulator ( to my knowledge). Doug
I don't know the line and fitting sizes, but my plan is to go with 3.2L fueling throughout (hard lines in tunnel + fuel filter). I haven't bought the lines yet, but assume that it can be done without opening up the pan on my '72. I want to avoid running AN lines underneath the car...
Also, no accumulator needed as far as I can see. I went with a full timmins kit and did buy AN lines from him in case I can't get factory lines into the tunnel.
![]() Hi Jeremy- Nice job on those lines. Re- the Accumulator, you don't need it for EFI. The 964/993 filter should do nicely. I think that has M16 threads. Just let me know what you need for fittings, they are only a Priority Mail package away. Len
![]() ![]() ![]() So laid out the harness - can anybody identify the plug? the directions are pretty matter of fact - and brief - I have the patrick harness. lines are pretty much complete (except for one of the front lines - that the banjo fitting did not have enough room on)
