3.2 Air Filter Clip - Any Tips?
How do you get the back, lower air filter clip re-attached?
I changed the air filter and got three clips re-attached. I can't get my hand behind te air box to clip the last one.
This is an OEM air box on a 1985 Carrera with a stock 3.2 engine.
Thank in advance.
Lawrence
Old 05-31-2011, 05:42 AM
cdrik915's Avatar
You can re-attach it easily ; but you should try to do that with your left hand BEHIND the airbox , and on its left side.
LIGHTER = FASTER !!!
Old 05-31-2011, 05:58 AM
To make it easier I bent the clip a bit to take some of the tension out of it. So now I can manipulate it with just the tips of my fingers. It still fits snug and requires less cursing. Ken
Ken in Greer, SC
88 Carrera Coupe
98 C2S Coupe
Old 05-31-2011, 06:08 AM
Northern Motorhead
wildcat077's Avatar
I loosen the AFM assembly temporarily as i could move the aibox just enough to clip the rear brackets ...
Cheers!
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
I've pushed it home with a long 3/8 extension from the left. It's a pain. I don't even know why they put clips there in the first place.
Old 05-31-2011, 06:29 AM
a lot of swearing and it will eventually clip. i tried as some have stated to put a zip wrap on the clip but i ended up ripping the zip wrap. you will end up with some feeling loss on your finger. i'll try the making it less tight as one has suggested next time.
ken
87 targa
Old 05-31-2011, 06:58 AM
Thinner arms make a big difference. Get your wife or GF to do it for you.
Old 05-31-2011, 07:08 AM
Wine User
warner53's Avatar
take the oil filler cap off and you will have more reach.
W
Old 05-31-2011, 07:10 AM
3.2 air filter clip
I ran a wire thru the clip and when the other clip is in place, just pull on the wire.
Old 05-31-2011, 07:59 AM
Thank you for the tips. I'll try again using some of these suggestions.
Old 05-31-2011, 08:47 AM
Super_Dave_D's Avatar
I ask my wife to step into the garage for a minute.
2015 Audi S3
1988 Carrera Coupe (gone and miss her)
Old 05-31-2011, 09:07 AM
carreraken's Avatar
Be careful - I broke this clip on mine... ended up finding a used replacement airbox..
Ken
06 Cayman S - gone
85 911 Targa - gone back home to Germany
73.5 911T Targa - long gone...
Founder ncPOG: nevada county Porsche Owners Group - disbanded post covid after 15 yrs
Old 05-31-2011, 09:15 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Or you can mod it buy cutting the top end portion of the cover off. Easy Peasy to apply the clips and easy access to the oil filter and refill of oil if you do not have a funnel handy.
Side effects: louder exhaust at upper RPMS
'85 Carrera Targa
PCA/POC
Old 05-31-2011, 12:38 PM
dshepp806's Avatar
I can get to mine just fine....I've a broken clip and will be removing this mother to attempt a plastic weld.....no way am I placing any metal L-brackets, nut, bolts,..in there....if it doesn't work,..then we'll get a new air box (no big deal)>
BEST!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 05-31-2011, 02:31 PM
83 911 Production Cab #10
JJ 911SC's Avatar
If you were married to a red hair... You would still walk funny
Who Will Live... Will See
Old 05-31-2011, 04:51 PM
KNS KNS is offline
Try not to break them, new airboxes are NLA
Kurt
Old 05-31-2011, 06:15 PM
Registered Loser
I had my 10 year old son attach the rear clips, see:
Current Rides:: 1987 Red 911 Targa, 2007 R320 CDI, 2003 Red Dodge Ram Hemi, 1993 Beater Jeep Cherokee, Airbus A320
Gone but not forgotten: 1981 VW Scirocco S, 1989 Honda Accord Coupe LXI, F-16C (still my favorite vehicle!),MC-130P, C-130E, T-38, T-37, C150, C172, PA180
Old 05-31-2011, 07:42 PM
DRACO A5OG's Avatar
Whoa, is that a PAG SST?
Now I found a reason to have a kid, but how do you keep them small to get back there and fit their arms between the manifolds?
Jim
'85 Carrera Targa
PCA/POC
Old 05-31-2011, 07:53 PM
Be very gentle on the airbox, as has been stated. Attach all 4 clips each time.
I remove the air compressor bolts and place it on top of the right side manifold. It's the hoses that are in the way. This will open up plenty of room to get to the clip. Takes about 20 mins to do this and put it back plus retighten the belt. Worth it, imo.
Old 05-31-2011, 08:07 PM
DRACO A5OG's Avatar
Please forgive the Hi-Jack, but you guys with OEM Air Boxes.
Do you have the Wierd "STOP" aka Air Cleaner Cap connected to the nipple in the rear, if so what is your Breather Hose doing, just flopping loose?
Air Cleaner Cap 84-89 OEM Air Box
'85 Carrera Targa
PCA/POC
Old 05-31-2011, 08:36 PM
