Always learning
whats wrong with this fitting?
![]() A pair of these came in a box with other parts for my resto. It appears to be relatively new. It is the shine down license light from a '66. Can someone please tell me, how this could possibly work? Is this the correct part? Looking at it, its seems to be defective due to the fitting automaitcally shorting. Ie the current goes straight back to the chasis of the car via the holder.... Thanks for the replies. Roland |
Does one end of the lamp have ceramic insulation surrounding the contact point?
Always learning
One end has a plastic insulator... The other is a pressed brass fitting that connects directly to the frame of the unit. What I dont understand is the holder appears to short the bulb...
Flat Six
Any chance it's wearing the wrong bulb? Looks like a narrower and longer bulb would allow the bulb holder in the middle of the bracket to contact glass rather than the metal end of the bulb, thus not shorting out the lamp.
Just my $.02.
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport |
The only thing i can imagine is that the metal L bracket portion is designed to hold the bulb in place around the glass portion of the bulb. It looks like something was lost in translation. Wrong bulb?
Always learning
![]() Here is an image from another site (sorry wayne). It appears slightly longer albeiet skinnier. It would therefore rattle around in the holder. Is there supposed to be something around the metal bracket that holds the bulb? Does anyone have an image please? |
Always learning
That would be "Albeit"
Platinum Member
Looks like it should take a bayonete bulb like this:
![]() Take the bulb out and take a pic of the hole. If it has 2 slots around the circle, it's a bayonet socket. |
Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Almost Banned Once
Wrong bulb in the first pic. The brass plug at the other end is for connecting the tag for the earth cable only.
- Peter |
Almost Banned Once
Two pictures from our host.
Note: @ 41 & 42... 42 is a bayonet bulb. ![]()
- Peter |
Ha! Somebody put the wrong bulb in there! It takes a bayonet base bulb. The bulb itself does not bulge out from the base, it looks like the eraser end of a pencil.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
+1 for LJ851's idea that the "L bracket is pressed in backwards. The bulb is correct.
On edit - that won't work either, the bracket won't let the light reach the terminal. How about using electrical tape on ID of the bracket? - klugey, but would work. Or isolate entire bracket from chassis. yeah, somethings wrong
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue Last edited by steely; 06-01-2011 at 07:48 PM.. |
I think dad911 nailed it .
Always learning
just tried the bayonet - spot on. Thanks folks... Feel like a dill... Always learning I guess!
Aha - I mistakenly though those tubular bulbs came with the assy.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
Almost Banned Once
You need 20 lashes with a wet boot lace...
- Peter |
