Turn signals
I have a '77 911 which is in very good condition - more interior cosmetic issues really. I read a recent post where the gauges were sent out and fully reconditioned. This is one of my future plans - possibly this winter. My question - the turn indicator in the speedo - when I use the turn signal both lights - left and right - come on. Is this due to the age and close proximity of the indicator or can this be changed when the gauge is reconditioned?
'77 Porsche 911S |
I had this problem in my Porsche and BMW. It is indicating a blown bulb or electrical fault. Have someone stand behind the car and tell you what the lights are doing while you activate the turn signals, brakes, etc.
___________________________________________ John '84 911 Cab '98 TL1000R |
The lights work outside - it's the one in the speedo where it shows both direction - just want to know if this is normal.
'77 Porsche 911S |
Member 911 Anonymous
No not normal, check your wiring if good then send it back to shop to correct it
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Probably a missing/poor earth connection on the speedo, they are rubber mounted so if the earth is poor then the return path is through the other light bulb. Simple to run a temporary earth with a jumper cable or similar.
1972 911T Coupe with a '73E MFI engine and 'S' pistons 10 year resto mostly completed, in original Albert Blue. ***If only I didn't know now what I didn't know then*** |
