-   -   1978 to 1973 RSR Build Project (http://forums.pelicanparts.com/porsche-911-technical-forum/613850-1978-1973-rsr-build-project.html)
wayner 07-26-2011 04:54 AM
Thanks for the oil cooler info James!
JEM911 07-26-2011 05:59 PM
Got some engine updates today! These photo's are of crankshaft and clutch being balanced. Also some pic's of the rod's being weighed. I know that the piston's have been weighed and matched ready for the build.
Crank & Clutch
http://forums.pelicanparts.com/uploa...1311728133.jpg
Crank & Clutch - Spinning
http://forums.pelicanparts.com/uploa...1311728148.jpg
Rods
http://forums.pelicanparts.com/uploa...1311728212.jpg
Kroggers 07-27-2011 01:52 AM
Cool build - keep the info coming please...
JEM911 07-29-2011 06:44 PM
So I have some updated photo's on the body work. We are all but ready for paint, and you can see the work completed to get this into shape and ready for it...
http://forums.pelicanparts.com/uploa...1311990153.jpg
http://forums.pelicanparts.com/uploa...1311990181.jpg
http://forums.pelicanparts.com/uploa...1311990201.jpg
JEM911 07-29-2011 06:46 PM
http://forums.pelicanparts.com/uploa...1311990349.jpg
http://forums.pelicanparts.com/uploa...1311990366.jpg
JEM911 08-10-2011 06:22 PM
Motec Computer Panel
Saw the updated Motec Panel layout today.
I think a picture says a thousand words. Not much more to say...
http://forums.pelicanparts.com/uploa...1313025707.jpg
totle 08-11-2011 01:17 AM
Nice project. Subscribed :-)
turbolader 08-11-2011 07:41 AM
I wonder what the reasoning would be for not allowing a "welded in" roll-cage car on the public roadway? Perhaps just wanting to keep fast race cars from multiplying on the streets and highways? Great build!
Strygaldwir 08-11-2011 08:11 AM
Roll cages and unhelmeted heads don't play well together perhaps?
Flieger 08-11-2011 11:29 AM
Bolt in are closer to driver than weld in.
JEM911 08-11-2011 02:12 PM
unfortunately our roads and traffic authority in NSW, Australia, is well... S#$t. They have adopted a zero tolerance approach to just about anything modified. The reasoning went something like this:
' If we allow modified vehicles on the road, and these modifications aren't done correctly the vehicle may perform worse than the factory specification, thus unsafe for driver and the rest of the community'
that's the essence of the concept. unfortunately a few too many idiot built backyard cages etc, were involved in accidents, and subsequently the "cage" was at fault. It's a great example of how they use misguided statistics to validate a view. By this I mean if you have a traffic accident (assume a minor rear end collision), yet you had a front roll cage, the cage would be a contributing factor. Forget the drivers stupidity, you have a front cage therefore your vision is impeded, so its the cage's fault.
Go figure?
(it's a raw point from my perspective)
J.J. 08-11-2011 05:26 PM
an Aussie build, killer.. will be watching this one
JEM911 08-12-2011 08:39 AM
External body works
So I got the external body work images today.
The body has been walnut blasted, and then hand finished. It's great getting back to this stage as you find any potential issues before the paint and it all become too late to deal with.
http://forums.pelicanparts.com/uploa...1313163492.jpg
http://forums.pelicanparts.com/uploa...1313163505.jpg
with the internal ready to go, and only a bit of external work left to finish it won't be long until we get some color down.
Flieger 08-12-2011 11:02 AM
So if you went to the authorities and told them you wanted to install an FIA certified cage in your car to protect yourself from the other crazy drivers out there, they would tell you to bugger off and drive your classic with minimal protection from the thin pillars?
sc_rufctr 08-12-2011 11:10 AM
In my state you can only have a half cage (only from the back of the seats, back)
JEM911 08-12-2011 02:07 PM
Yes! How stupid is this system?
There are three essential 'issues' they have with the roll cage.
1. The cage running down along the A-Pillar would 'block your view' - so you can't drive safely
2. The cage intrusion bars protecting driver from a side impact are unsafe because in an accident they will crush you, and you will die (or some similar stupid logic)
3. A cage in the front near the firewall etc will also kill you in a accident because it will crush you (see comment on point 2).
It's the dumbest approach is the world. It's really driven by people who have done dodgy cages, then been in accidents. They don't think as far motorsports success with using cages to 'survive', only the fact that in an accident, done wrongly will impede you chances of surviving.
rexav8r 08-12-2011 03:42 PM
Fantastic project !! Would you do the same for my '78 SC ??!!
Question: When you balance the crank and clutch like this, what are you trimming into balance ?? It would make sense to my feeble brain to shave the clutch since you will eventually be changing that down the road...
smestas 08-12-2011 04:08 PM
*subscribed*
Canada Kev 08-12-2011 09:59 PM
By this logic, you should stay in bed because you might get struck by a falling meteor while crossing the street...
JEM911 08-19-2011 08:53 PM
Short Block Assembly
Attached are some pictures of the short block assembly.
I'm envisaging getting pictures of the long block assembly mid next week to share with everyone.
http://forums.pelicanparts.com/uploa...1313812278.jpg
http://forums.pelicanparts.com/uploa...1313812293.jpg
http://forums.pelicanparts.com/uploa...1313812313.jpg
Basically body and engine are being worked on at the same time.
The body should be ready for paint (at least the undercarriage) by next week as well. This looks like it will start to come together at the perfect time.
JEM911 08-22-2011 08:02 PM
Updated photo's of the body... Having had the car walnut blasted, the entire car is almost all lined up and ready to paint....
http://forums.pelicanparts.com/uploa...1314068462.jpg
http://forums.pelicanparts.com/uploa...1314068474.jpg
http://forums.pelicanparts.com/uploa...1314068483.jpg
Mothy 08-22-2011 08:28 PM
You might want to check a bit further with some of the Sydney Porsche shops - If what you say is correct, then how do they get GT3RS's registered in NSW? They have a full cage with only the side bars as bolt in.
The side bars are generally not allowed to be welded in as the view is they impede access and egress in an emergency - same reason you are not allowed to wear full harness seatbelt on the road.
Would love to see the car at a Porsche Club of NSW track day when it gets here.
Tim
giovanni86 08-22-2011 11:46 PM
:eek:
mph911 08-22-2011 11:58 PM
Tim
Im pretty sure they are registered with the back half of the cage and the front section and sidebars bolt up.
JEM911 08-23-2011 03:15 AM
I'm fairly sure that this is the case as well.
The rules from what I can see are very difficult to deal with. IE certain front cages could get approved - such as those hard up against the firewall. But these cages cannot connect to the rear - only by bolt in for these sections...
Also newly manufactured and registered vehicles have it easier in a round about way...
The joys of the RTA in NSW.
JEM911 08-23-2011 06:04 PM
Update from Patrick Motorsports
So, my project has been deemed worthy of the Patrick Motorsports website. You can visit the link
http://www.patrickmotorsports.com/project/57/http://www.patrickmotorsports.com/project/57/
Most of the images I have posted are on the forum, but there are a couple of things that have been left off.
Hoping to have the long block pictures to be posted later this week.
will hung 08-24-2011 04:51 AM
Out of curiosity, why is the engine cover grill filled? Awesome project.
JEM911 08-24-2011 02:20 PM
The probably best explanation is on the Patrick Motorsports website:
Patrick Motorsports - 1974 Carrera RSR Twin Turbo
Essentially because we have to fit the 993TT engine (including inter-coolers), you need to fabricate a 'new' deck-lid with clearance.
will hung 08-25-2011 05:05 AM
I see. So it'll kind of be like a whale-ducktail. They flatten the top to clearance the intercooler. I figured it had something to do with the intercoolers, but was just curious. I wasn't sure if they'd use the OEM routing of the intercooler, or if they'd take Ruf's routing and lay the intercoolers on either side of the engine inside of the engine compartment. So I see that they'll be using the OEM routing.
Fantastic project.
Flieger 08-25-2011 10:50 AM
So they are going to cut holes/slots in it later?
I have seen 930s with custom bent/cut+welded intercoolers that fit under normal ducktails without shrouding.
JEM911 08-25-2011 06:57 PM
There will be holes cut into them eventually once the final gaps are all sorted on the body.
It's better to get the most efficient design / layout for the engine, then get the body to fit afterwards.
JEM911 08-27-2011 12:43 AM
Long Block
Got further pictures today of the engine build...
http://forums.pelicanparts.com/uploa...1314430949.jpg
http://forums.pelicanparts.com/uploa...1314430968.jpg
JEM911 09-01-2011 07:35 PM
In high fill prior to paint
What a difference a week and a bit makes, the car is almost ready now!
Attached are the pictures of the high filled car just about ready for paint. I'm so excited now, I can almost see the car put together! admittedly i know its a bit longer to go but its a big step
http://forums.pelicanparts.com/uploa...1314930808.gif
http://forums.pelicanparts.com/uploa...1314930875.gif
JEM911 09-24-2011 12:52 AM
Got the seats today...
We got the seats on Friday which is awesome. The wheels are due next week....
http://forums.pelicanparts.com/uploa...1316844412.jpg
Paint has been a pain in the ass. For some reason the slate grey code seems to be different from a few different paint companies. There's a bit of difference, but I'm close to getting it right.
At the end of the day I don't really think it's going to matter, as the car isn't original in any event, but I do want to get it as close to right as possible.
The set back with color has put this all back a bit. Hopefully we will be on track this week.
JEM911 10-05-2011 02:55 PM
Test fitting prior to paint
So because we needed to cut out the duck tail, and it obviously needed to occur prior to being painted, the car's been back in fabrication getting the last test fit prior to painting.
The long and short of it all is that we've moved the engine forward as much as possible to get clearance on the inter-cooler. We also need this because there isn't a great deal of room for the exhaust back there, so it's a lot easier to do the test fit now, without the worry of paint than after paint has occurred.
Also it was decided that we should prepare and test fit all the oil lines etc now, include fabricate any brackets, clip spots, etc, so they all get painted and look as factory as possible.
The long and short of it is that it's not seeing paint this week.
http://forums.pelicanparts.com/uploa...1317851640.jpg
but you do get to seem some photos of the car coming together...
http://forums.pelicanparts.com/uploa...1317851666.jpg
which is a small consolation prize, because it's looking good.
wayner 10-05-2011 03:03 PM
It DOES look good!!
shbop 10-05-2011 06:16 PM
wow...
MrShades 10-06-2011 10:21 AM
Great looking car:) Everything looks so perfect
Do you use brackets for holding the turbos or are they sitting on the exhaust pipes?
giovanni86 10-06-2011 10:56 AM
superb car
(are you sure about the colour? )
911pcars 10-06-2011 12:25 PM
I like watching.
S
