-   -   1978 to 1973 RSR Build Project (http://forums.pelicanparts.com/porsche-911-technical-forum/613850-1978-1973-rsr-build-project.html)
JEM911 06-13-2011 04:04 PM
Hi All,
New poster, however long time reader of these forum's. Thought that seeing I was building a new project, and that I've read to much of the forum I should probably post my progress as I go, to let everyone else have some benefits from my build project.
I guess i'm the classic "cheque-book" tuner at this stage, although I have built numerous other non-Porsche project, being my first Porsche build, I have engaged Patrick Motorsports. I didn't originally plan to get someone else to do this build, but I contacted Scott @ Patrick for the G50 conversion information. Long story short, we got talking and one thing lead to another, hence we're now building my project in there shop.
I originally bought a 1973 911T shell, with the plans to restore that, however upon pulling down the car we quickly found too much rust to salvage the project. After doing some searching, James from Patrick Motorsports offered me a 1978 Turbo, which was in a good condition.
http://forums.pelicanparts.com/uploa...1308006109.jpg
Anyway the project plan is as follows:
  1. Convert the Body to 1973/74 RSR style
  2. Buy and build a 993TT Engine
  3. Modify all the engine, suspension and other components to make as good as reasonably possible
  4. paint a traditional color
  5. Enjoy the rest of the car!
I'll try and do updates as I go, I have a few historical picture to get everyone upto date on the project thus far.
JEM911 06-13-2011 04:09 PM
Chassis Works
I'm putting the shortened G50 6 Speed Transmission in, so we had to make some minor modifications...
http://forums.pelicanparts.com/uploa...1308006501.jpg
http://forums.pelicanparts.com/uploa...1308006522.jpg
We also just started getting the "ducktail" and front nose conversion started...
http://forums.pelicanparts.com/uploa...1308006565.jpg
http://forums.pelicanparts.com/uploa...1308006575.jpg
JEM911 06-13-2011 04:16 PM
Holiday Delays
So, the upside of getting someone else to do this work is that it's all coming together a lot faster than if I had done it myself.
http://forums.pelicanparts.com/uploa...1308006674.jpg
The front is now starting to all line up and match nicely...
http://forums.pelicanparts.com/uploa...1308006693.jpg
provisions and planning for the inter-cooler and air jack system have started...
http://forums.pelicanparts.com/uploa...1308006768.jpg
front air-jack point
http://forums.pelicanparts.com/uploa...1308006895.jpg
bracket fabrication for air jacks
http://forums.pelicanparts.com/uploa...1308006925.jpg
http://forums.pelicanparts.com/uploa...1308006940.jpg
rear air jacks in place for fitment
http://forums.pelicanparts.com/uploa...1308006958.jpg
http://forums.pelicanparts.com/uploa...1308006977.jpg
JEM911 06-13-2011 04:21 PM
Roll cage
So we started with the fabrication for the roll-cage.
I'm at a bit of a loss here, and i'm getting told a lot of conflicting stories about was it legal in Australia (specifically NSW). There are a lot of issues with getting roll cages engineered in Australia, so I need to get this right... below is the rear (which isn't much of a problem)
http://forums.pelicanparts.com/uploa...1308007171.jpg
This shows the air-jacks now welded in, and the rear cage positioning.
http://forums.pelicanparts.com/uploa...1308007290.jpg
onboost 06-13-2011 05:52 PM
Nice welding/fab work.. should be an interesting build. Enjoy!
dhagood 06-13-2011 06:33 PM
i presume this is a dedicated race car build?
Jack Olsen 06-13-2011 10:32 PM
Very nice!
JEM911 06-14-2011 02:26 AM
No! I actually intend on road registering the car in NSW, Australia. That said, I have hit a few minor (actually major) issues with our Roads & Traffic Authority, and the regulations surrounding various modifications I've made.
Specifically they won't allow a full welded in roll-cage (biggest issue)...
However there are still a couple of hurdles on the emissions front to overcome, as well as noise.
AFCuk 06-14-2011 04:28 AM
Nice :cool:
kycarguy 935 06-14-2011 04:49 AM
Nice project! Will be following this one.
John S 06-14-2011 05:11 AM
James, nice looking details. Should be fast. I'm curious about your emission "hurdles"
I would have thought you'd be fine as you're replacing the existing engine with a newer, and therefore, "cleaner" one. Or are you planning on using a non-factory computer?
JEM911 06-14-2011 05:47 AM
I'm planning on using the Motec system. I would like to build this to circa 600+HP. I figure that it's a good goal, which is achievable.
I understand that the engine needs to meet the later emission standards - that is the 993 emissions, as opposed to the 930 emissions.
Unless you know otherwise?
911lvr 06-14-2011 06:27 AM
Id love to see more about the air jacks as well.. nice build
GH85Carrera 06-14-2011 06:45 AM
Wow, nice build.
That will be one heck of a car. It looks like a left hand drive car. Will that cause problems down under?
AlexJ 06-14-2011 07:39 AM
Hi James,
Is it possible to inform where did you buy the panel marked on the photo? Or did you fabricate it?
http://forums.pelicanparts.com/uploa...1308062319.jpg
If any other person can help, I'll appreciate.
Cory M 06-14-2011 09:25 AM
looks like a top notch project, can't wait to see more progress
JEM911 06-14-2011 03:06 PM
Originally Posted by GH85Carrera (Post 6078595)
Wow, nice build.
No, we can drive registered LHD cars. However I do understand that they are looking to change this in the future for newly imported vehicles.
Hopefully I finish the build before they change the rules!
JEM911 06-14-2011 03:10 PM
Originally Posted by AlexJ (Post 6078676)
Hi James,
Patrick Motorsports are doing the build. I would suggest that you email Scott McIlvain <scott@patrickmotorsports.com>, I had a look on there website and couldn't find the part, so best to give them a buzz.
FinallyGotOne 06-14-2011 03:24 PM
This is going to be a fun one to follow!
John S 06-14-2011 04:35 PM
Yes, the engine has to meet emissions it was complianced to meet. I don't know how you'll get past that with the motec, and will watch with interest your progress with this issue.
600 bhp in the little car:eek: that will be interesting. I'd have trouble with the standard 408 bhp. Looks like you're building an early interpretation of a GT2. Crazy fun! Hopefully I'll get to see it at some stage here in town.
cardsrule 06-14-2011 10:15 PM
James,
I share in your excitement in this project. I love to see it evolve everyday and cannot wait to hear it fire up for the first time! If anyone has any questions about this project please give me a PM or post them and I will do my best to answer them. I will keep getting James photos so he can update this thread.
We build some great Porsche's but this one is going to be truly one of a kind!!!!
Sincerely,
Scott
JEM911 06-15-2011 03:26 AM
I spoke with the guys at Patrick Motorsports today, with the news that I can't put a full cage in, we have now finished the fabrication stage. So it's going to body for paint preparation.
Re the Motec - A couple of people I have spoken with seem to think that I can get it through, just a bit of planning and work... time will tell.
I'll definitely get the car out and about in Sydney once it arrives. A early GT2 is very much my inspiration.
ShakinJoe 06-15-2011 05:18 PM
Very cool. Sorry about the cage!
JEM911 06-16-2011 06:47 PM
Got some pics of the Transmission today
So James Patrick and Patrick Motorsports sent me a late email today with some photo's of the six speed G50, short bell housing transmission. So excited! I decided that spending the extra bit on a 6 speed was worth it! It's been completely overhauled so it should be exciting...
http://forums.pelicanparts.com/uploa...1308275223.jpg
http://forums.pelicanparts.com/uploa...1308275234.jpg
JEM911 06-18-2011 02:26 AM
So a couple of people have PM'd me about Patrick Motorsports, and wanted references etc as to there work.
I can only be very positive and say that they have been really helpful. For those with questions around the quality of work etc, I thought its best that I just post the sort of photo's I get from them on the build...
So today I got some pictures showing the welding on the cage....
http://forums.pelicanparts.com/uploa...1308388972.jpg
http://forums.pelicanparts.com/uploa...1308388995.jpg
http://forums.pelicanparts.com/uploa...1308389013.jpg
Anyway I'm really happy with the build to date. If anyone wants to know more feel free to post or PM me.
vas930 06-19-2011 02:35 AM
Just love the whole idea James. I am in Vic and would love to drive up and have a look when its done. Maybe a road trip in the 930. Good luck mate.
Walko 06-19-2011 04:04 AM
James ,
I would suggest you get Patrick to make the cage but not weld the front half in until you have been through rego.
Btw awesome looking project
Regards
Michael
JEM911 06-19-2011 04:44 AM
I've decided to just do a rear half cage.
Registration is a nightmare, I wish the RTA would look at these things as improvements where they are done professionally and with care and thought. The problem is all the "half-jobs" which have ruined it for those who want to do it right. I had been considering doing another car, but the registration and import rules, not to mention the duties just keeps making me thing its not worth the effort.
On other news, I had a small accident yesterday in my C2S. I got cut off and mounted the gutter. I should have let him hit me, at least I wouldn't have been at fault. Not really sure the extent of the damage, at least two rims. Perhaps some suspension components. Very annoying seeing I had just spent the weekend painting the wheels black. Anyway I'm really p#$Sed off about the entire thing.
0396 06-19-2011 07:58 AM
very very nice and informative, enjoy in good health!
Facey 06-19-2011 10:40 AM
Sorry to hear about the accident -> hopefully you're fine and it's just the wheels!
scotricker 06-19-2011 10:44 AM
Sorry to hear of your off road experience... but you pictures make me want to go get a welder....and then some skills, too I guess. :)
JEM911 06-22-2011 06:33 PM
So I got a couple of pictures today of the heads from the 993 TT that we're building... thought I should share:
http://forums.pelicanparts.com/uploa...1308792699.jpg
http://forums.pelicanparts.com/uploa...1308792720.jpg
So this now completes all the major engine components that were needed to get the long block built. I'm hoping that early next week it will get put back together, and I will be sharing photo's of a built engine.
On the other fronts, the body is about to be taken back to bare metal for paint preparation, so that's exciting. Again when I get some photo's I will share them with you all...
AKA 930 07-11-2011 02:48 PM
Subscribed...
vas930 07-23-2011 07:54 PM
Any update on the project James?
JEM911 07-24-2011 03:59 AM
I had a discussion with the guys at Patrick Motorsports on Saturday morning (Sydney) which is Friday afternoon in Phoenix, AZ.
The car is next in line for the paint shop, so I'm hoping to have some pictures this week with progress.
The engine is all in component form, and I'm expecting to get photo's of its build when it occurs (again this should hopefully be this week).
Both are going to be built simultaneously so hopefully i'll have great pictures in the next week to share.
sc_rufctr 07-24-2011 04:24 AM
I'm so bloody jealous...
(Good luck with everything)
RODI 07-24-2011 04:39 AM
awesome...
wayner 07-25-2011 08:41 AM
What size oil cooler are you putting on that?
I'm doing up a 73 with RSR bumper and the giant cooler that came with this project has no hope of fitting behind the bumper, even with significant ducting.
JEM911 07-25-2011 06:47 PM
Patrick Motorsports are supplying the part... you can find it @
Patrick Motorsports - PMP 500-15NPT3/4 911 930 FRONT NOSE OIL COOLER 934 935 RS RSR RACE RACING
Also,
I'm using fender coolers which are:
Patrick Motorsports - 911 930 FRONT FENDER COOLER OIL SET 50 150 7612http://forums.pelicanparts.com/uploa...1311644753.jpg
http://forums.pelicanparts.com/uploa...1311644782.jpg
Canada Kev 07-25-2011 08:01 PM
I wonder if one of these would more or less bolt right in to a G50 911. I see that the front bracket has been cut or machined off. How about provisions for mounting the cross member?
