1978 to 1973 RSR Build Project
Hi All,
New poster, however long time reader of these forum's. Thought that seeing I was building a new project, and that I've read to much of the forum I should probably post my progress as I go, to let everyone else have some benefits from my build project. I guess i'm the classic "cheque-book" tuner at this stage, although I have built numerous other non-Porsche project, being my first Porsche build, I have engaged Patrick Motorsports. I didn't originally plan to get someone else to do this build, but I contacted Scott @ Patrick for the G50 conversion information. Long story short, we got talking and one thing lead to another, hence we're now building my project in there shop. I originally bought a 1973 911T shell, with the plans to restore that, however upon pulling down the car we quickly found too much rust to salvage the project. After doing some searching, James from Patrick Motorsports offered me a 1978 Turbo, which was in a good condition. http://forums.pelicanparts.com/uploa...1308006109.jpg Anyway the project plan is as follows:
I'll try and do updates as I go, I have a few historical picture to get everyone upto date on the project thus far. |
Chassis Works
I'm putting the shortened G50 6 Speed Transmission in, so we had to make some minor modifications...
http://forums.pelicanparts.com/uploa...1308006501.jpg http://forums.pelicanparts.com/uploa...1308006522.jpg We also just started getting the "ducktail" and front nose conversion started... http://forums.pelicanparts.com/uploa...1308006565.jpg http://forums.pelicanparts.com/uploa...1308006575.jpg |
Holiday Delays
So, the upside of getting someone else to do this work is that it's all coming together a lot faster than if I had done it myself.
http://forums.pelicanparts.com/uploa...1308006674.jpg The front is now starting to all line up and match nicely... http://forums.pelicanparts.com/uploa...1308006693.jpg provisions and planning for the inter-cooler and air jack system have started... http://forums.pelicanparts.com/uploa...1308006768.jpg front air-jack point http://forums.pelicanparts.com/uploa...1308006895.jpg bracket fabrication for air jacks http://forums.pelicanparts.com/uploa...1308006925.jpg http://forums.pelicanparts.com/uploa...1308006940.jpg rear air jacks in place for fitment http://forums.pelicanparts.com/uploa...1308006958.jpg http://forums.pelicanparts.com/uploa...1308006977.jpg |
Roll cage
So we started with the fabrication for the roll-cage.
I'm at a bit of a loss here, and i'm getting told a lot of conflicting stories about was it legal in Australia (specifically NSW). There are a lot of issues with getting roll cages engineered in Australia, so I need to get this right... below is the rear (which isn't much of a problem) http://forums.pelicanparts.com/uploa...1308007171.jpg This shows the air-jacks now welded in, and the rear cage positioning. http://forums.pelicanparts.com/uploa...1308007290.jpg |
Nice welding/fab work.. should be an interesting build. Enjoy!
i presume this is a dedicated race car build?
Very nice!
Specifically they won't allow a full welded in roll-cage (biggest issue)... However there are still a couple of hurdles on the emissions front to overcome, as well as noise. |
Nice :cool:
Nice project! Will be following this one.
James, nice looking details. Should be fast. I'm curious about your emission "hurdles"
I would have thought you'd be fine as you're replacing the existing engine with a newer, and therefore, "cleaner" one. Or are you planning on using a non-factory computer? |
I understand that the engine needs to meet the later emission standards - that is the 993 emissions, as opposed to the 930 emissions. Unless you know otherwise? |
Id love to see more about the air jacks as well.. nice build
Wow, nice build.
That will be one heck of a car. It looks like a left hand drive car. Will that cause problems down under? |
Hi James,
Is it possible to inform where did you buy the panel marked on the photo? Or did you fabricate it? http://forums.pelicanparts.com/uploa...1308062319.jpg If any other person can help, I'll appreciate. Thanks |
looks like a top notch project, can't wait to see more progress
Hopefully I finish the build before they change the rules! |
This is going to be a fun one to follow!
600 bhp in the little car:eek: that will be interesting. I'd have trouble with the standard 408 bhp. Looks like you're building an early interpretation of a GT2. Crazy fun! Hopefully I'll get to see it at some stage here in town. |
| All times are GMT -8. The time now is 02:27 PM. |
