-   -   1978 to 1973 RSR Build Project (http://forums.pelicanparts.com/porsche-911-technical-forum/613850-1978-1973-rsr-build-project.html)
wayner 07-26-2011 04:54 AM
Thanks for the oil cooler info James!
JEM911 07-26-2011 05:59 PM
Got some engine updates today! These photo's are of crankshaft and clutch being balanced. Also some pic's of the rod's being weighed. I know that the piston's have been weighed and matched ready for the build.
Crank & Clutch
http://forums.pelicanparts.com/uploa...1311728133.jpg
Crank & Clutch - Spinning
http://forums.pelicanparts.com/uploa...1311728148.jpg
Rods
http://forums.pelicanparts.com/uploa...1311728212.jpg
Kroggers 07-27-2011 01:52 AM
Cool build - keep the info coming please...
JEM911 07-29-2011 06:44 PM
So I have some updated photo's on the body work. We are all but ready for paint, and you can see the work completed to get this into shape and ready for it...
http://forums.pelicanparts.com/uploa...1311990153.jpg
http://forums.pelicanparts.com/uploa...1311990181.jpg
http://forums.pelicanparts.com/uploa...1311990201.jpg
JEM911 07-29-2011 06:46 PM
http://forums.pelicanparts.com/uploa...1311990349.jpg
http://forums.pelicanparts.com/uploa...1311990366.jpg
JEM911 08-10-2011 06:22 PM
Motec Computer Panel
Saw the updated Motec Panel layout today.
I think a picture says a thousand words. Not much more to say...
http://forums.pelicanparts.com/uploa...1313025707.jpg
totle 08-11-2011 01:17 AM
Nice project. Subscribed :-)
turbolader 08-11-2011 07:41 AM
I wonder what the reasoning would be for not allowing a "welded in" roll-cage car on the public roadway? Perhaps just wanting to keep fast race cars from multiplying on the streets and highways? Great build!
Strygaldwir 08-11-2011 08:11 AM
Roll cages and unhelmeted heads don't play well together perhaps?
Flieger 08-11-2011 11:29 AM
Bolt in are closer to driver than weld in.
JEM911 08-11-2011 02:12 PM
unfortunately our roads and traffic authority in NSW, Australia, is well... S#$t. They have adopted a zero tolerance approach to just about anything modified. The reasoning went something like this:
' If we allow modified vehicles on the road, and these modifications aren't done correctly the vehicle may perform worse than the factory specification, thus unsafe for driver and the rest of the community'
that's the essence of the concept. unfortunately a few too many idiot built backyard cages etc, were involved in accidents, and subsequently the "cage" was at fault. It's a great example of how they use misguided statistics to validate a view. By this I mean if you have a traffic accident (assume a minor rear end collision), yet you had a front roll cage, the cage would be a contributing factor. Forget the drivers stupidity, you have a front cage therefore your vision is impeded, so its the cage's fault.
Go figure?
(it's a raw point from my perspective)
J.J. 08-11-2011 05:26 PM
an Aussie build, killer.. will be watching this one
JEM911 08-12-2011 08:39 AM
External body works
So I got the external body work images today.
The body has been walnut blasted, and then hand finished. It's great getting back to this stage as you find any potential issues before the paint and it all become too late to deal with.
http://forums.pelicanparts.com/uploa...1313163492.jpg
http://forums.pelicanparts.com/uploa...1313163505.jpg
with the internal ready to go, and only a bit of external work left to finish it won't be long until we get some color down.
Flieger 08-12-2011 11:02 AM
So if you went to the authorities and told them you wanted to install an FIA certified cage in your car to protect yourself from the other crazy drivers out there, they would tell you to bugger off and drive your classic with minimal protection from the thin pillars?
sc_rufctr 08-12-2011 11:10 AM
In my state you can only have a half cage (only from the back of the seats, back)
JEM911 08-12-2011 02:07 PM
Yes! How stupid is this system?
There are three essential 'issues' they have with the roll cage.
1. The cage running down along the A-Pillar would 'block your view' - so you can't drive safely
2. The cage intrusion bars protecting driver from a side impact are unsafe because in an accident they will crush you, and you will die (or some similar stupid logic)
3. A cage in the front near the firewall etc will also kill you in a accident because it will crush you (see comment on point 2).
It's the dumbest approach is the world. It's really driven by people who have done dodgy cages, then been in accidents. They don't think as far motorsports success with using cages to 'survive', only the fact that in an accident, done wrongly will impede you chances of surviving.
rexav8r 08-12-2011 03:42 PM
Fantastic project !! Would you do the same for my '78 SC ??!!
Question: When you balance the crank and clutch like this, what are you trimming into balance ?? It would make sense to my feeble brain to shave the clutch since you will eventually be changing that down the road...
smestas 08-12-2011 04:08 PM
*subscribed*
Canada Kev 08-12-2011 09:59 PM
By this logic, you should stay in bed because you might get struck by a falling meteor while crossing the street...
JEM911 08-19-2011 08:53 PM
Short Block Assembly
Attached are some pictures of the short block assembly.
I'm envisaging getting pictures of the long block assembly mid next week to share with everyone.
http://forums.pelicanparts.com/uploa...1313812278.jpg
http://forums.pelicanparts.com/uploa...1313812293.jpg
http://forums.pelicanparts.com/uploa...1313812313.jpg
Basically body and engine are being worked on at the same time.
The body should be ready for paint (at least the undercarriage) by next week as well. This looks like it will start to come together at the perfect time.
