Always learning
Pic of bracket desperately needed please
Does anyone have some close up pics of the brackets that sit on the top of the parcel shelf that the parcel shelf bar affixes to? Any measurements of the size/height would be great. Need to make some up....Really appreciate your help.
Old 06-16-2011, 04:20 PM
Walt Fricke's Avatar
Even for you I'm not going to crawl past my roll cage into the back seat to pry up the covering parts and look.
If these brackets are what is needed to screw the upholstery down, I recall them being smallish rectangles, L shaped at each end (where they were welded down), and just tall enough so that the screws which went through them didn't bump into the tub sheet metal.
How did you end up with a tub minus these parts? Is that the way replacement sheet metal comes?
And I may be remembering the brackets which held the screws for the two (on my '77) black cast fittings intended to hold luggage or something onto the shelf, which are on top of the upholstery.
But somebody out there has a tub with the package shelf upholstery removed who can help you.
Old 06-16-2011, 05:43 PM
Always learning
Brackets
Thanks Walt.
I'm miffed as to why mine has no brackets, or signs of their existence once upon a time. My car came as a rolling chassis. Ive never even sat in an early 901 nor driven one. Trying to work out what goes where has been arduous. I come from the land of 356's...
Anyway, almost done
Old 06-16-2011, 08:08 PM
Bracket
Rolls
This is a pic of what is in my SC.
Sorry, I never had my parcel shelf out of my 912.
Can't imagine they'd changed it much over the years though.
Hope this helps.
Scott
'78 SC mit Sportomatic - Sold
Old 06-16-2011, 08:52 PM
Always learning
Thanks but...
Thanks Scott. I actually need a picture of the center brackets - the ones that attach to the center bar. Thanks anyway though...
Old 06-17-2011, 03:09 AM
Always learning
Bump
Anyone.... Common ....I'm standing here with the mig in one hand and some sheet steel in the other! Last job before I fire her up.....
Old 06-17-2011, 07:04 PM
Send a message via Skype™ to Porboynz
I have a 1972 911 and there is no centre bracket on the parcel shelf, there are brackets as per the photo Scott posted that the so called luggage brackets attach to through the upholstery. There is also a bracket spot welded to the centre of the engine firewall that the uphostery attaches to. I have a mostly bare stock interior and happy to take photos if you can specify exactly where you want.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 06-17-2011, 11:08 PM
SP2 SP2 is offline
SP2's Avatar
Check your other thread.
James
1969 911E Slate Grey
1981 911SC Wine Red
1997 911C4S Ocean Blue
Old 06-17-2011, 11:38 PM
