83 911 Production Cab #10
Start to put her back together.
I installed the tin around the engine (86 3.2) and went on to installed the SSI. The one on the the driver (LH) side (pics showing engine upside down) definitely interferes with the SSI. Anybody else encounter this (could not find it in any search result) and what is the solution, snip away? Old HE ![]() ![]() SSI ![]() ![]()
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
a.k.a. G-man
I'm bumping this since I have SSI's as well that i need to install.
Is there a difference between the later and earlier pieces of engine tin on that location?
Сидеть, ложь, Переворачиваться |
I had a similar problem on a MFI car.
yes, the earlier cars don't have tin that sticks out like that. Its usually flush with the back of the motor.
james www.gruppe9autowerks.com Its not how fast you go...its how you go fast |
on my car i only had to pound the SSI edge up to fit
No big deal ![]()
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
This just happened to me with a pair of George's headers. The tin is important there due to the head temp sensor. I just rolled the tin up to accommodate the headers. Was fairly simple using a huge crescent wrench to grip and and form. Used a shop rag in between jaws and sheetmetal.
Tru6 Restoration & Design |
wannabee wannabee
I guess an 84 tin is different..
Mine clears... and as mentioned you MIGHT need to pound one area on the SSI to clear the clutch spring..
99 C4 - (let's try this once more) 07 Cayman S - sold 11/17 (not the same) 84 Carrera - sold 3/16 (geez what have I done!) |
Did you roll in inward or outward? Pics if available. Cheers JJ
JJ, I rolled up if that makes sense. Just in from the car now, I'll take some pics tomorrow afternoon and post.
JJ........just getting her put together I see. Good luck.......I'm in town in a few weeks.
1984 911 Coupe 2007 Z4 M Coupe 2008 Cayman S 2004 M3-Alpine White(sold) 2002 M Roadster (sold) |
![]() If not we'll have a few beers ![]()
here you go.
Shaun
Perfect. That is the way I pictured it. On you 1st photo, does you oil line touch the engine (at 6 O'clock, around the transmission)? Cheers JJ
Glad to help. The oil line does not touch at 6 o'clock, but the it does touch the cylinder sheet metal a tiny bit. I was told not to worry about it. It is coming off to have the rubber hose finished. We cut it down to meet up with custom high clearance oil lines.
Thread Tools | |
Rate This Thread | |
