Sherwood,
I use dye.. I have found it better in finding small leaks..
My $.02...
70 911T Sold 81 911SC Coupe
84 Mustang Turbo GT
66 Galaxy 500 Ragtop (my Mother bought it new)
88 Thunderbird Turbo Coupe
69 Torino Cobra (R) Code
Old 06-20-2011, 03:38 PM
Gary H 1978 911 SC
I just went through a upgrade and found several leaks. I replaced my old evaporator with a larger M.Benz and a 928 blower and a custom box to hold it.I had 1 hose off of the dryer leaking and replaced all hoses. The last leak that threw me was the shaft seal on the compressor. I am in Texas and need cold air.Good luck
Old 06-20-2011, 04:40 PM
Originally Posted by Neel View Post
Sherwood,
My $.02...
A couple of schools of thought. Yes. Dye and flourescent leak detector can be used. There are a couple of caveats. Dye displaces refrigerant capacity. On older, R-12 systems with enough capacity, inserting dye can have negligible effect on cooling capacity. However, on newer vehicles designed for an exact volume of R134a/HC110A, the system capacities are smaller in volume. With dye, there's less volume for refrigerant. It's also impossible to know how many times dye has been added during previous A/C service and POs.
In addition, a strategic refrigerant/dye leak in the interior can/will stain clothing and upholstery. Fortunately, the stain will only be visible with a black light. Unfortunately, the stain can be permanent if not removed.
That's the conservative approach anyway.
Sherwood
Old 06-20-2011, 05:25 PM
