83 911 Production Cab #10
JJ 911SC's Avatar
Exclamation Help: SSI / Engine Tin Installation Problem
Start to put her back together.
I installed the tin around the engine (86 3.2) and went on to installed the SSI.
The one on the the driver (LH) side (pics showing engine upside down) definitely interferes with the SSI.
Anybody else encounter this (could not find it in any search result) and what is the solution, snip away?
Old HE
SSI
Who Will Live... Will See
Old 06-19-2011, 05:19 AM
a.k.a. G-man
Geronimo '74's Avatar
I'm bumping this since I have SSI's as well that i need to install.
Is there a difference between the later and earlier pieces of engine tin on that location?
Old 06-20-2011, 12:12 AM
j911brick's Avatar
I had a similar problem on a MFI car.
yes, the earlier cars don't have tin that sticks out like that. Its usually flush with the back of the motor.
james
www.gruppe9autowerks.com
Its not how fast you go...its how you go fast
Old 06-20-2011, 02:43 AM
on my car i only had to pound the SSI edge up to fit
No big deal
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-20-2011, 06:03 AM
Shaun @ Tru6's Avatar
This just happened to me with a pair of George's headers. The tin is important there due to the head temp sensor. I just rolled the tin up to accommodate the headers. Was fairly simple using a huge crescent wrench to grip and and form. Used a shop rag in between jaws and sheetmetal.
Tru6 Restoration & Design
Old 06-20-2011, 06:10 AM
wannabee wannabee
WIL84911's Avatar
I guess an 84 tin is different..
Mine clears... and as mentioned you MIGHT need to pound one area on the SSI to clear the clutch spring..
99 C4 - (let's try this once more)
07 Cayman S - sold 11/17 (not the same)
84 Carrera - sold 3/16 (geez what have I done!)
Old 06-20-2011, 07:27 AM
JJ 911SC's Avatar
Shawn
Did you roll in inward or outward? Pics if available.
Cheers
JJ
Old 06-20-2011, 05:03 PM
JJ, I rolled up if that makes sense. Just in from the car now, I'll take some pics tomorrow afternoon and post.
Old 06-20-2011, 06:16 PM
JJ 911SC's Avatar
Thanks, it will help mentally
Old 06-20-2011, 07:09 PM
NewfieMZ3's Avatar
JJ........just getting her put together I see. Good luck.......I'm in town in a few weeks.
1984 911 Coupe
2007 Z4 M Coupe
2008 Cayman S
2004 M3-Alpine White(sold)
2002 M Roadster (sold)
Old 06-20-2011, 08:21 PM
JJ 911SC's Avatar
Maybe I'll be on the road by then
If not we'll have a few beers
Old 06-20-2011, 08:57 PM
here you go.
Old 06-21-2011, 04:44 AM
JJ 911SC's Avatar
Porsche Crest
Shaun
Perfect. That is the way I pictured it.
On you 1st photo, does you oil line touch the engine (at 6 O'clock, around the transmission)?
Cheers
JJ
Old 06-21-2011, 05:56 AM
Glad to help. The oil line does not touch at 6 o'clock, but the it does touch the cylinder sheet metal a tiny bit. I was told not to worry about it. It is coming off to have the rubber hose finished. We cut it down to meet up with custom high clearance oil lines.
Old 06-21-2011, 06:08 AM
