Macht Schnell
les_garten's Avatar
MaxJax?
Any of you guys ues the MaxJax with a 911/930? I'm going to get one I think and wanted to know if there were any issues?
Les
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT
Old 06-22-2011, 05:43 PM
Almost Banned Once
sc_rufctr's Avatar
Les
I've been doing some research for a lift... The MaxJack does looks great and is a good price but it looks way too uncertain to me.
The 5 bolts going into the floor are the only thing holding the posts upright.
IMHO... You're much better off with a hoist with the two posts braced across the top or with a flat plate across the floor.
That seems a lot more sensible to me.
- Peter
Old 06-22-2011, 05:56 PM
Macht Schnell
les_garten's Avatar
Yeah, I just don't have the room. I'm just a little over 8' ceilings in my garage. The research on the anchors is supposed to be way over engineered if they are installed correctly. I would get epoxy set anchors which are even stronger.
Old 06-22-2011, 06:13 PM
Almost Banned Once
sc_rufctr's Avatar
I understand that but why even risk it?
Don't get me wrong the MaxJack has a lot going for it. The ability to move it easily is a great idea.
What's above the ceiling in your garage? You could extend the posts into the ceiling and have the cross brace in there as well.
Like this from and older thread.
- Peter
Old 06-22-2011, 06:20 PM
Navin Johnson
TimT's Avatar
Five bolts on each leg should provide ample anchoring...
The unknown is what you are anchoring the legs of the lift to...
A four inch slab that was placed with a eight inch slump might not be a good candidate to set this lift on.. and that slab might very well be the way the contractor placed your garage slab...
Since that lift does not have any sort of bracing tying the legs together... I would investigate the floor you will anchor it to... drill a hole in the slab and measure the thickness... Is suspect you can get some sonotube and make your own piers and not worry about the anchorage etc..
'69 911 GT-5
'75 914 GT-3
and others
Old 06-22-2011, 06:24 PM
Macht Schnell
les_garten's Avatar
What is a slump? I looked up the Sonotube stuff.
Old 06-22-2011, 06:35 PM
I had considered it for my old garage. Then when I drilled into the concrete I found that the old concrete was not up to the task. I was happy I got a 4 post instead.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 06-22-2011, 06:52 PM
Navin Johnson
TimT's Avatar
Slump is a representation of the amount of water in the concrete mix...
Contractors love to add more water because is makes the concrete easier to move around and finish...which you would think is a good thing.....BUT!
But there is a point where concrete mixes have to much water.. then strength,durability etc go out the window..
I.e. on a 3000 psi mix, the specified slump might be 2-4 in +/- (0.5) in.... at the high range 4.5 in its pretty workable... Its even easier if it comes out of the truck at 6 in...
The finishers can easily close the surface... the laborers can easily move the mix... And the owner has a slab that does not meet the minimum strength requirement...
My concerns regarding anchoring not only this lift, but any lift, is that what you are anchoring to is an unknown variable, unless you witnessed the placement of the slab...
check the thickness at the least... I'm sure MaxJax mentions a minimum slab thickness in the installation manual
'69 911 GT-5
'75 914 GT-3
and others
Old 06-22-2011, 07:00 PM
Navin Johnson
TimT's Avatar
Graphically....
Now I have no idea if this applies to your situation.... but....having dealt with contractors for 30 years I may be jaded..
'69 911 GT-5
'75 914 GT-3
and others
Old 06-22-2011, 07:07 PM
Macht Schnell
les_garten's Avatar
The specs call for 4" 3000 psi concrete, which is what I have. Although I didn't witness it. The builder is known here for well built over spec'd houses in my area. Home was built in 2006.
I don't want to cut the ceiling. It's a finished garage with floored attic above.
Old 06-22-2011, 07:11 PM
coolcavaracing.com
Kroggers's Avatar
Send a message via Skype™ to Kroggers
I was also looking into this lift and went as far as get shipping quotes to Finland. But in the end decided against the MaxJax and got a good scissor lift instead. My reasons were:-
1.- Not convinced that the slab in my garage is strong enough.
2.- Whilst the MaxJax is movable - it is not a quick process to relocate it (it bolts to the floor!) A scissor lift can easily be moved to another location in the garage and used.
3.- I could get a really good scissor lift with TUV approval from Germany cheaper than the MaxJax.
Pĺl (Paul) - The Norwegian lost in Finland...
1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!)
come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing
Old 06-23-2011, 02:56 AM
DanielDudley's Avatar
Garage Journal has hundreds of satisfied Max Jack users, and hundreds of pages of discussion on jacks and lifts.
You should find something you like there.
Old 06-23-2011, 03:06 AM
Slippery Slope Victim
NY65912's Avatar
Listen to TimT, he may not know much,but this he knows
Mike˛
1985 M491
Old 06-23-2011, 04:17 AM
Macht Schnell
les_garten's Avatar
I'm over there as well. The reason I posted over here was to find out any 911 specific issues. I had my 911 up on an old 2 post jack and always had a hard time getting it situated on the arms, because the arms were too long to swing around the wheels. I had to floor jack the 911 to get the arms under it.
Old 06-23-2011, 07:15 AM
additional add to jaded comments....
plans say 4" slab...
what is handy? 2x4's and they are not 4" more like 3.5" and if they deflect when screeding less
this is why I had my driveway spec'd and poured at 5" and the concrete guys hated me when I watched, thought I was a know it all when I found places not meeting 5" and wanted the base well compacted like the plans say, enough said on that, 20 years later and I don't have a crack in my driveway but I also spec'd the rebar placing/etc.
Old 06-23-2011, 07:36 AM
jsmithcds's Avatar
max jax
I have a max jax and it does exactly what it was made to do. I had about 3.5 inches of conrete so the anchors they sent had to be modified a bit.
I got the 6" extensions that came as an option to give me a little more head room under it if I plan on having it up for a while.
I use it all the time. Cleaning the wheels?? Let's do that at eye level........
Really easy to install and when the pump is put away your garage looks clean.
79sc Flared with a 3.2SS conversion 9.5:1 J&E's with 964 cams and M&K exhaust
Viper Green
He who laughs, lasts.
Old 06-23-2011, 08:21 AM
Macht Schnell
les_garten's Avatar
I like the Green!
Can you give me your inside post to inside post measurement? Do you have any problems swinging the arms past the wheels? I'm trying to figure out the range for the post install holes. My 930 is not handy right now. I also have a MB 300 TE wagon and a Toy Landcruiser.
Old 06-23-2011, 08:28 AM
Administrator
Jack Olsen's Avatar
MaxJax makes me nervous only in that they seem to encourage a user installation. With a two-post lift like that, the floor becomes a structural component of what is holding the car. Assuming the bolts torque correctly and your pad is stable, everything is fine. I've never seen (or heard or read about) a MaxJax failure. But the safety-conservative in me thinks a scissor jack is a safer bet, since it asks so little of the existing pad and the installer -- and is so well suited to the architecture of a 911.
In my own case, I went in a direction that would probably make my inner safety-conservative go nuts, if I saw someone else doing it. But I believe I covered my bases.
It's just something you don't want to be at all casual about. Dropping 3,000 pounds of car in an enclosed space is a really scary thing.
Old 06-23-2011, 08:30 AM
jsmithcds's Avatar
mounting
I would have to take a measurement on the distance apart. I have marks on the floor for were my front and rear tire need to be close to so that the pads all clear the wheels. Just takes a little trial and error to get it right then mark it out on the floor. I'll shoot you a PM tomorrow sometime. If I forget remind me.
Too close ='s cannot open the doors. To far ='s car has to be in the perfect location between lift towers both front to back to lift.
By all means Jack's installation is awsome. Watch the video. Killer!!
Viper Green
Old 06-23-2011, 09:14 AM
Macht Schnell
les_garten's Avatar
Thanx!
Old 06-23-2011, 09:18 AM
