Imcoz's Avatar
Originally Posted by syzygy View Post
I just got one for my G50. I really like the positive feel. It's quite precise and makes a large difference over stock. However, because of the somewhat noisy nature of the G50 tranny, it (the shifter) does vibrate a little between 2 and 3K RPM. It stops if I put my hand lightly on the shift knob.
Mmm! I just got back from two days of hard DE at NJMP's Thunderbolt Course... I can't say I noticed any vibration with mine. Maybe it's something further down than the shifter.
Coz
88 911
72 914-6 Vintage Racer
76 914-6 Vintage Racer
Old 06-27-2011, 09:50 AM
moneymanager's Avatar
Thanks Pete, I have seen the earlier threads, but no one has really addressed my question. I'm not sure about shortening the throw... there are people on this thread who say the WEVO does nothing there. And the appearance... I frankly think the WEVO is the klutziest looking add-on you could find. But lets forget aesthetics... people like different looks. I still don't think I've seen anything by anyone who had seriously tried both and has an informed opinion as to the functionality of each. I have a Seine, and like it. I'd trade it in for a Wevo, (or the Rennline product which many prefer) if anyone could tell me how one of those is superior. I don't doubt that it may be, I'd just like some evidence.
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 06-27-2011, 09:55 AM
cdrik915's Avatar
I installed my Wevo shifter last year.
After some hesitations in adjusting , i found finally the good position (Shifter and PSJ) , and that has changed my gearbox feeling : more precision , more sensations .
For me THE upgrade to purchase.
But that needs adjustments , precises adjustments to be perfect.
Just my opinion.
LIGHTER = FASTER !!!
Old 06-27-2011, 10:22 AM
Nice responses thanks. I currently have a Seine w/short shift kit that is set up pretty well right now. I'd like to drive a properly set up WEVO but from what it sounds it wont be much of an upgrade. Interesting.
1980 911SC Targa 3.6L
Old 06-27-2011, 10:49 AM
gtc gtc is offline
abides.
gtc's Avatar
Originally Posted by AirKuhl View Post
There is actually one thing I don't like that much. At certain revs in 3rd and 4th gear only, there is occasionally a bit of rattle. However, that might be more in the linkage than the shifter, I'll have to look into it. It goes away if I press the shifter to the left a bit.
I would pull the shifter out of the car and clean and relube it. There are a few parts that could be loose, namely the end of your shift rod inside the tunnel, and the set screw that holds the wevo shift lever pivot box. (I'd guess the set screw)
Also, I did have to replace my brass plunger tips after many thousands of miles... they had worn down a bit, which gave me a bit of side-to-side slop.
Love my WEVO, though, and Hayden was very nice and helpful in getting me the parts quickly.
Graham
1984 Carrera Targa
Old 06-27-2011, 11:02 AM
DG624's Avatar
I have never liked the 915 transmission although it is lighter. Mine was badly worn when I bought it and I had it rebuilt with new 1st 2nd gears and syncros...still hard to shift especially when going from 3rd to 2nd downshift. I changed the rear bushings and went to a factory short shift kit but it still is very stiff and seems like a truck. Does the WEVO or Sein Systems kit make it shift smoother and quicker?
Old 06-27-2011, 03:23 PM
The best shifter won't overcome any deficiencies inside the gearbox. Whether the gearbox synchros are wearing, worn or healthy, I suggest learning how to double-clutch in order to select the desired gear and/or to extend gearbox life.
As for reducing shift throws, the Wevo provides this capability. The Seine Systems Gate Shift kit does not, but using the factory short shift kit with it produces an equivalent result in that respect.
MHO,
Sherwood
(affiliated)
Old 06-27-2011, 06:15 PM
jsmithcds's Avatar
gate shift
I just installed the siene gate shift to my existing short shift(which I did not even know I had) along with new bushings under the stick and a stromski coupler in the rear. All this for $350 and 3 hours of work. Not sure on the wevo set up but I am now a firm believer in the new set up I have.
79sc Flared with a 3.2SS conversion 9.5:1 J&E's with 964 cams and M&K exhaust
Viper Green
He who laughs, lasts.
Old 06-27-2011, 07:55 PM
I had the shift gate installed in my 915 when I had TRE rebuild it. I had to upgrade the rest of the system fast because the gateshift made everything so precise. I put in the WEVO coupler, all new bushings and a factory short shift kit......what a difference. the 915 is sweet.
I have no desire for a new shifter. Mine looks very stock and it is OEM [couple little mods though], and it works great.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 06-27-2011, 08:34 PM
pcar9119's Avatar
I skipped both of these and went with the hargett shifter in my 915. I have only had the chance to drive it a couple of times, but, I can't imagine anything on the market that does a better job than this shifter system...
Old 06-28-2011, 12:04 AM
