Who doesnt like their WEVO shifter?
All I hear on this board is raves but a friend of mine has the Wevo shifter and it is difficult to get used to. I'm guessing its an installation issue. Anyone else not care for their Wevo after installed?
1980 911SC Targa 3.6L |
Mine is kinda boring. It makes choosing the intended gear SOOOOO predictable.
I hate knowing what gear I'm choosing..
86 Carrera POC Racecar 07 Cayman S 13 Tacoma TRD Sport 16 VW Sportwagen |
1984-911 M491
You want boring, add the WEVO gateshift.. now that's boring!
1984-911 TLC......SOLD |
RETIRED
What's not to like?
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Schleprock
The spring-centering effect without the gate tabs (old shifter has the tab on the shifter that captures the other tab atop the shift housing in 5th-Reverse plane) doesn't hold the shifter in place like it should and relieve the spring pressure on the shift forks? That's one reason why I chose the Seine gate shift thingamajigger kit because it mimics what the original shifter does in 5th and reverse.
Kevin L '86 Carrera "Larry" |
Almost Banned Once
It's a good upgrade but often people install one thinking it will "fix" all of their problems.
It's not worth a "pinch of p**" if your 915 or your bushes are worn out. Before any upgrade like this I would check and double check everything else. Make any adjustments and replace bushings as needed so your 915 shifts like it did from the factory. Once you're happy THEN install the WEVO... I bought a RENSHIFT and I'm very happy with it but when I first installed it I felt disappointed. Long story short my 78 915 was in need of a rebuild but I didn't know that at the time. OK... So now I have a gearbox from and 83 and the RENSHIFT I'm more than happy with the results. The centre springing of 3~4 make the biggest difference to the feel of the shift. The SEINE Gate Shift Kit also looks like a great option. I like it because you keep most of your OEM Shifter. If I ever do this again I would definitely try the SEINE Gate Shift Kit.
- Peter |
Member 911 Anonymous
Siene Gate Shift Kit is kind of boring too, no more WTF? shifting up to 3rd. I really miss the miss shift to 1st, so sad.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
be here now
I belong to the "I love my WEVO" club!
Rob.... '66 911, '74 911, '85.5 944, '69 914-6, '65 356C, '01 986, '04 955S, '97 993 C2S, '55 356 OUTLAW, '98 993 Cab, '55 356 Speedster, '06 955S, '58 356A, '96 993 C4S, '87 BD 911, '95 993, '06 997S, '11 997.2S, '74 914 2.7, '15 981S |
GOM (Grumpy Old Man)
I didn't like the name Wevo so I went with Rennshift.
![]() Seriously, I don't think you will find many people (if any) who don't like their Wevo shifters, thus the sarcasm in this thread.
Instagram: @3pedalposse |
I'd answer but I like mine.
Seriously... As someone else mentioned it doesn't cure transmission issues. It doesn't even 'cure' the crappy throw from first to second. What it does do and this is what I got it for. It makes much more precision shifts for the track. There you don't care about first or second. The shifting between third, fourth & fifth are awesome, and of course downshifting.
O2 In Sully We Believe |
I don't like my Wevo shifter.
I LOVE my Wevo shifter, especially when you've got a lot of other things going on, like trail braking to throttle on, happening right quick. |
I like my Wevo for my race car. I would not like it for a street car due to the reasons stated by Kevin. In my car I can hear tranny noise from the spring loading on the shift forks in 1,2 and 5th. I think that if you put the gateshift inside the tranny, that would alleviate the spring loading on the shift forks.
-Andy
72 Carrera RS replica, Spec 911 racer |
70 911T Sold 81 911SC Coupe84 Mustang Turbo GT 66 Galaxy 500 Ragtop (my Mother bought it new) 88 Thunderbird Turbo Coupe 69 Torino Cobra (R) Code |
There is actually one thing I don't like that much. At certain revs in 3rd and 4th gear only, there is occasionally a bit of rattle. However, that might be more in the linkage than the shifter, I'll have to look into it. It goes away if I press the shifter to the left a bit.
And +1 for it not being a band-aid for other transmission woes. Need to get the tranny right first, then the shifter (whatever brand) is just icing on the cake. They all seem to be good, I got the Wevo because it's a local product and it looks cool. Non-Porsche folks often thnk I have a sequential tranny. Sometimes I don't correct them.
Maybe not saying much because it's on a G50, but I love my Wevo.
Coz 88 911 72 914-6 Vintage Racer 76 914-6 Vintage Racer |
I have not missed a shift to third since I installed my Wevo. What is not to like?
Formerly known as Syzygy
The unanswered question here is why spend $500 for a Wevo when the Seine shifter does pretty much the same thing for $200? I'd love to hear from someone who has sampled both. All the WEVO comments seem to say that shifting between 3rd and 4th is now wonderful as the shift lever is held nicely in that plane. Well, that is precisely what the Seine does, and does very well, perhaps even better as it doesn't have the vibration problem. What additionally does the WEVO do which makes people prefer it, if they do?
jhtaylor santa barbara 74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's. 73 Targa (gone but not forgotten) |
See here for a parts list. http://www.wevo.com/Products/ShifterProducts/ShifterImages/WEVO_915_Shifter_INSTRUCTIONS_2009.pdf |
