Where does this attach?
I was poking around in the front luggage compartment, and found this. Being still fairly new to the car, and not finding anything in my various manuals (admittedly, I didn't look *that* hard, with so many experts here) I need to know, where should this black plastic piece attach?
thanks!
1988 911 Carrera, M491 Cabriolet
2016 Cayenne
Old 06-27-2011, 05:14 PM
Almost Banned Once
sc_rufctr's Avatar
I think that's the vent for the battery. The idea is to vent the fumes to the outside of the car.
The other end exits to the outside the body somewhere. Trace it back and see were it goes.
There should be a hole in the top cover of the battery that it plugs into.
Also....Check for any spilt acid around the bottom of the battery. Because that's not plugged into the battery top you may have lost some battery acid.
- Peter
Old 06-27-2011, 05:18 PM
Wine User
warner53's Avatar
My guess is that it attaches to your headlight washer nozzle below your headlights.
Warner
Old 06-27-2011, 05:20 PM
Wash. State
nesslar's Avatar
? Pretty cool, a vent for what is probably a sealed battery.... I think maybe warner53 is closer to the truth; looks like water piping to me....
Old 06-27-2011, 05:32 PM
I don't have a headlight washer nozzle
2016 Cayenne
Old 06-27-2011, 06:37 PM
Wash. State
nesslar's Avatar
Really? Maybe the previous owner changed out the bumper...? Just a thought. I would think '88s would have 'em as standard equipment....but I don't know...
Old 06-27-2011, 06:55 PM
Eschews Obfuscation
dhagood's Avatar
Warner
+1
sure looks like washer fluid plumbing, although the nozzle would have been on the other side of the front bulkhead (ie, outside the tub).
'84 Porsche 911 Targa
'97 Ford F250 Heavy Duty
'98 Volvo S70
'02 Subaru Forester
'05 VW Passat TDI
Old 06-27-2011, 07:13 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Yeap, his garage shows the washer removed.
'85 Carrera Targa
PCA/POC
Old 06-27-2011, 07:18 PM
Hmm, I don't think it was removed, since there is no switch on the dashboard for a headlight washer, and there isn't any tubing going over to the right side where the other headlight would be.
2016 Cayenne
Old 06-27-2011, 08:44 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
if you dont know what it is, dont lead someone down the wrong path.
it is a battery vent.
the headlight washer tubing is all outside of the car, none in the trunk area, and you can see the windshield pump in his photo.
Old 06-27-2011, 10:01 PM
So I looked around the battery, which is fairly new, and found no place for this to attach. My guess is that the PO replaced the battery, and seeing no place to attach this vent, just left it dangling.
Is there any concern about this? Can I just leave it this way?
2016 Cayenne
Old 06-28-2011, 06:06 AM
Friend of Warren
Have you done this yet? If so, where does the other end of the tube go?
Kurt V
Old 06-28-2011, 06:30 AM
The other end of the tube, after about 6 inches, goes into a hole on the inside of the left front fender. So it can't be traced back very far. Maybe the issue here is that the newer battery either (A) does not require venting, so the tube is now unnecessary or (B) can be vented, but this connector did not fit.
2016 Cayenne
Old 06-28-2011, 07:36 AM
rattlsnak's Avatar
newer batteries vent through the top caps or out the top side IF at all.. (some have a 6" plastic tube running down the side)
in your case, answer: A
Old 06-28-2011, 08:59 AM
