Castrol VR1 Question
Bought some Castrol VR1 racing oil SAE 50. Got home and realized it's not the VR1 racing oil 20W 50 I already have on the shelf.
What's the difference? Thanks. |
Max Sluiter
Valvoline makes VR-1
Castrol makes GTX. You do not want GTX. Use something like Bradd Penn which is recommended in the ultimate oil thread. Do a search for that.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
What's wrong with Castrol GTX? The car I drive has used Castrol GTX exclusively for 274k miles and it has never been cracked open and runs like new. Castrol GTX and Kendall are the same oil. Brad Penn is the old Kendall green oil.
1988 Porsche 911 Targa - 210K miles Red / Black 1989 Porsche Carrera 4 - 59k miles Red / Black 1980 Porsche 928 - 5 speed / Cashmere beige / 183k miles |
Max Sluiter
Castrol GTX breaks down too soon- gets thin. The detergents are quite aggressive and can interfere with ZDDP formation despite the high mileage formulation having good levels of Zinc and Phosphorous.
I have never heard that Castrol GTX and the new Kendall are the same oil. Please cite your sources.
Max Sluiter
Please post all further replies here, after reading the first post:
Ultimate Motor Oil Thread or Why we hate CJ4/SM oils
I been using Castrol GTX 20/50 for 23 years and never had any problems. I do realize that there will always be new and improved enhanced products.
Max Sluiter
The Castrol you used 23 years ago was better than the newer Castrol formulations which have been regulated to save catalytic converters in engines with roller cam followers.
Sorry, sorry. I meant Valvoline VR1.
Just want to know how different 20w-50 is from SAE 50. |
Max Sluiter
I think SAE 50 is straight 50 weight no matter the temperature. 20W50 will change viscosity with temperature so cold starts will not be so hard on seals due to thick oil and high pressure. The downside is that the viscosity modifiers that allow that are not as durable so the oil will get thin and need changing more quickly. This is part of Castrol GTX's problem.
If you are racing this engine or live in a warm climate you might be able to get away with straight 50 weight if you are careful on cold starts. It will hold up to high temperatures better and will have lots of nice Zinc and Phosphorous that catalytic converters would choke on.
Castrol is made by Burmah Castrol PLC in the UK. Kendall is made by Conoco-Phillips in TX. You are fortunate to have good luck using GTX and I think that may be bigger testament to your maintenance regimen. My long-term experience with Castrol's US products isn't the same and we do not recommend the use of GTX in any vehicle.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
___________________________________________ John '84 911 Cab '98 TL1000R |
Northern, CA
Ground Hog Day
Anybody remember the movie Ground Hog Day with Bill Murray?
Is this it?
1989 Carrera Coupe |
Max Sluiter
