Cant argue with you on this. Altho its the only intelligent and truthful thing you said, based in facts, in the entire 35 page thread filled with otherwise useless drivel... ironically, you and wwest are alot alike. both spewing speculation as fact...
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
looks like you have taken over as the leader of the usless drivel here. I am making and supplying 911 A/C PARTS AND INVENTING MORE PRODUCTS I am not the BS like many here are Enjoy the obsolete A/C technology you bought GRIN |
AAEEEEE!
So no learning only flame baiting?
Steve Laissez les bons temps rouler |
Assuming a "clone", the front condensor fan may have been intentionally disabled just as I suggested. You might/will find that the 2 fans run in series, half speed, with the A/C switched on, both automatically go to full speed when the compressor clutch is engaged. With the increased efficiency of the rear condensor resulting form the additional cooling airflow you might not need the horribly inefficient front fan anyway. Do you have an opinion as to how well the system cools as is once the cabin is cooled down initially...? Last edited by wwest; 06-24-2013 at 09:11 PM.. |
sacoffee
Steve I have started writing a reply to you post here but am a little busy and will post it as soon as I can |
AAEEEEE!
Never put a thermometer on it but it blows really cold ... Problem is the amount / mass of cold air output, the system cant exchange enough air to keep up 111 F heat index day like yesterday. I would love to have more volume. The front condensor blower was frozen - took it apart tonight.
AAEEEEE!
No worries - you guys obviously know your stuff and we could learn a lot.
NO clue on the compressor! I am going to tell you straight up if you want to have colder A/C IN YOUR 911, you need to remove your old Porsche OEM Behr obsolete front and rear condensers and replace them with the newest technology condensers you can afford the more state of the art the better!!! Porsche made a major well known A/C design flaw in the body of the early model 911’s of not having enough A/C condenser SURFACE AREA room available in the original front and rear condenser placement area’s to allow the A/C to properly work until I came along and overcame the flaw using state of the art condenser heat exchanger technologies using my custom designed and engineered for early model 911’s PFC’s. Here is some helpful advice For your “front fan in the trunk not working”, the first thing you need to do is to find out and verify if FAN MOTOR is getting 12 volts electricity to the fan electric motor leads and the other fan electric motor lead you need to verify it IS grounded, if this true the fan motor should work if it is not damaged/burned out. Key switch on, A/C switch ON unless you want to start the engine which you do not have too. Also without the engine running with these switches both on you can sometimes hear a very slow turning motor maybe. Note there is an electric A/C relay switch usually inside of “the smugglers box; WHICH IS further/deeper inside your front hood area under a hinged plate with 2 movable tabs that when slid lets you open the smugglers box in the area around the sides of your black plastic evaporator box. Note also on top of the black plastic evaporator box the evaporator fan motor that is probably also fead electricity from the same relay as your front condenser squirrel-cage fan motor, you might have only a bad relay or loose wire? If you determine you need to replace your front condenser squirrel-cage fan motor or your evaporator blower motor in the future if damaged, I recommend if you’re going to use Porsche OEM parts to replace either of these 2 motors because they have failed to order the Porsche 1989 model year motors because they have higher RPM fan shaft speed then prior years motor models!!!! You can also just connect 2 wires to the battery and connect them carefully on the wire ends using alligator clips directly to the motors 2 wires and this way bypass the relay, going from positive and negative battery terminals to the positive and negative motor terminals; this will tell you right away if you have a bad electric blower motor Note your front condenser fan is very important, mostly for A/C cooling during stop and go traffic/driving or extended idling. Note your evaporator fan puts out the coldest A/C air temps into your cabin when the fan speed is set on lowest speed; NOT HIGH SPEED!!!! I am not going to say much about your OEM condensers except the 2 rear deck lid condenser fans and relays are useless I seal my PFC’s to the rear deck lid and use the engine fan because it is far more then needed I have posted a wealth of information here if you can take the time to find and read what interests you and you will learn a lot |
That would imply you have adequate condensing capability even without the front fan. "..blower was frozen.." That would imply a blown fuse. Given the circumstances the PO may have ignored.... |
Did not Happen. I offered to test... And I never heard from you. Too busy making crap up and quoting 20 hear old Google lab info. Nice imaginary gig you have going here...
Good god. Don't get your info from Wwest. Lol he just makes it up as he goes. Do a search.
"..use the engine fan becuase it is far more than needed.." Isn't it pretty obvious that the above is NOT the case, even with ANY aftermarket condensor design, given the engine cooling airflow improvement Porsche did with the 964 to increase just the engine cooling capability....?? Last edited by wwest; 06-25-2013 at 06:44 AM.. |
These are just amazing threads. I don't think there have been many threads at all on this board that have gone this long, and haven't been locked due to all the crap being flung at each other. And for the most part, all because of A/C, frickn classic! Super entertaining though, glad I don't have a/c in my poorscha.
72 911 Although it is done at the moment, it will never be finished. |
Banned
Banned
Oh, don't get me wrong my other car has a\c and I use it once in a while here in chicago, but this thread is nuts!
Banned
Banned
