Just rebuilt my AFM - Holy Crap!!!!
After reading the step-by-step for the 944 AFM rebuild, I decided to go for it this weekend after suffering though all sorts of stumbling, surging and poor idle for so long. I should have done this months ago! It was very straightforward and while the 944 article is fairly complete, it does leave out some of the remove/replace steps. It took:
30 min. to remove AFM from car. 15 min. to rebuild AFM 30 min. to clean and semi-polish AFM exterior (heck, why not make it look like you did something?) 30 min. to re-install AFM and test drive. And if I did this sort of thing for a living, I could probably have done in half the time. BTW, I have an extra AFM for a 3.2 (that needs rebuilding) -Bill
'87 Black on Black Targa - my second BLACK Targa... didn't learn the first time. __________ '72 El Camino - 550HP pro-tourer |
Thought about doing this too, any noticeable difference?
P.S.: Any pics of your El Camino?
My AFM has about 240k miles on it, so I could probably stand to do this myself. Where are these instructions?
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
Here is the article I was using for most of the info. Air Flow Meter (AFM) - from "The 944 Motronic DME" by FR Wilk* ©2001 www.the944.com There is also some stuff in Youtube as well.
The biggest improvement is the part throttle surging is GONE. Also, idle is less choppy. I had picked up a used AFM from eBay, did a basic bench test that showed no major issues, and had a service tech install that a few weeks ago, to help (hopefully) pass smog. It did pass, but ran like crap - much worse than my original, so that's what prompted me to rebuild my original and swap it with the eBay one. I now have an extra AFM that I plan to rebuild and sell. Anyone interested? BTW, here is some video of the Elky(it's still 'in-progress')
Very good info! Thanks.
What exactly did you "rebuild" in there?
BEST! Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
'Rebuild' may not be the best term, but what I basically did (as the article describes) is clean and re-align the the wiper arm to a new path on the conductive plastic strip. Just like trying to save a P&G fader that has seen too many late night sessions..
![]() I also cleaned all friction contact areas, a quick blast of air to blow out any dust/debris, and resealed the black plastic cover with hi-temp silicone.
I don't even have an AFM on my 911 but I really like the sound of the Elky.
If you listen closely, you can hear the opening drums of "Hot for Teacher". ![]() I like the ZR1 wheels as well.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne Last edited by Oh Haha; 07-18-2011 at 05:10 PM.. |
Far from a "rebuild",....for sure: fresh copper contact can be had quite easily on that "sweep",..and "yes" it certainly CAN contribute to various weirdness(s)....
I will definately NOT EVER touch that damned spring!!!!!!!!!!!! Fresh copper=GOOD!!!!!!!! BEST! Doyle
Member 911 Anonymous
Nice, love to see a video of your bench test on the next re-fresh
![]() Congrats!
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Chain fence eating turbo
Doc,
Sent you a Private Message ![]() Inquiring about the Airflow Meter you have for sale.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
