Removing A/C: R134
I've had the car for over 7 years. The PO upgraded to R134. It blew barely cool when I picked it up and never cared for it. One of the hoses has chaffed against the lid and has been slowly leaking A/C oil in the engine bay along the right side getting my Magnecor wires wet with this goo. The car's up on stands with no wheels nor front suspension so now's the time to rip out the A/C
![]() So, the question is, can I undo the hoses and deal with the A/C oil with an oil pan? Is there more to this than just undoing the hoses and pulling compressor, condensors?
Henri Owned for 21 years: '87 Carrera coupe Venetian blue |
Member 911 Anonymous
Unlike R12 this one will not require you to bring her into an authorized shop to release the refrigerant into the air.
If you protect yourself, wear a mask, R134a is linked to Testicular Cancer. Try your best not to inhale it as much as you can help it.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Drago - do you have any evidence to back up your claims of carcinogenicity?
If oil is leaking out of the hose, then there is very little, if any, refrigerant left. Particularly after 7 years without (I assume) any recharge.
There really shouldn't be that much oil either, typically just a couple of ounces in the sytem, so you shouldn't need to worry about an oil pan. To remove the system it's really pretty straightforward. The part that sometimes trips people up is that you have to remove the resistor pack under the passenger side floorboard in order to pull the evaporator out of the smugglers box. And if you plan on selling the used parts be careful not to break the white capillary tube from the temp switch that's inserted into the evaporator. Once you break that tube the temp switch is useless.
1986 Carrera Coupe 1999 Chevy Tahoe 1987 Chevy Blazer 1955 Chevy Apache 3100 Pickup "A little knowledge is a dangerous thing" Last edited by Barrpete; 07-11-2011 at 08:17 AM.. |
Fleabit peanut monkey
There is little oil in the system (even when full) to deal with to answer your original question. We are talking ounces not quarts.
There is no refrigerant in the system left if the oil is from the AC system leaking. On a preservation note, I bet you can find a high pressure side hose to the lid condenser pretty cheap. You sure you want to pitch the system? |
most asthma (and other) inhalers use R134a as a propellant. Last edited by tcar; 07-11-2011 at 01:15 PM.. |
