Case leaks and noisy valves is where I started.. The valves were because the cams were gone, and the case leaks, well since you have to split the thing to really fix them there was my engine rebuild. And as long as I was doing that I went ahead and rebuilt the transmission. 5K wasn't even the entry point for that though.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
steve215, where are you located? In southern NH, we had many P cars guys that love to tinker!!!
74' 911 w/3.2L (sold) 95' 993 C2 Triple Blk Cab. 02 Honda Superhawk (sold) 2018 Toyota Tundra Limited 2004 CRF250X |
Did the same thing - picked up my car without a PPI. Your bound to find some things, you live and learn. Look at it this way - you will get to know your a whole lot better. I know I have.
Agree with Joe Bob that looking for a rebuilt 915 could be a good idea. Every now and then nice ones turns up at a good price. Good thing about these cars is how relatively easy they are to work on yourself. Worst case if you get yourself in too deep then you tow the damn thing to someone who can clean up your mess. ![]()
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452) 911E Coupe -70 Carrera 3,2 -84 Sold |
RETIRED
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
76 911S Targa
I'm with Kontak. $500 and a little sweat and you will have everything fixed except the tranny. When you do it yourself you know what was done and you know who to blame if it doesn't work. You will learn so much more about how the car works, doing it yourself, that the education alone is worth the time it takes to do the work. Definitely pay for the alignment though.
Canucks Fan
Finn
From the Deep Dark Jungle |
Canucks Fan
Nice lookin ride BTW
winter
You will be OK, I think. Start getting ready to get some oil under your fingernails! You'll save a lot of $$$ and you'll know it's been done right. Plenty of help here, and be sure to use the search function to read up on projects prior to going with the wrenches flying!
Good luck with her!
Tom '76 Targa |
cycling has-been
betcha the bearing replacement is wear and tear related to the monster wheel and tire combo on an 81. Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
1984 Carrera Coupe 3.2
Hi Steve215, Nice color and looks super clean on the shiny side-sounds like you're going to make out very well, and have a great car when you fix up a few things. Enjoy!
<insert witty title here>
For $10k, I think you still got a pretty good deal. If it were me, I'd leave the tranny for now and fix everything else - it's all DIY-able. Though when it comes to alignment, I opted to take mine into the shop and pay the $200 or whatever it cost.
Get the valve adjustment tool and some silicone gaskets from Pelican, DIY the valve adjustment and fix the leak, give yourself 3 hours for this for your first time. But definitely DIY. Chain housing gaskets - piece of cake. Do it at the same time, while you've got all the oil drained out. Exhaust leak - couple gaskets, maybe some sealant. Tie rod - piece of cake, and cheap. Rear shocks aren't too expensive, and easy to swap out - budget an hour for your first time, but I replaced bushings on mine a few weeks ago and it took me under half an hour for both sides. If the ride feels fine to you, leave the front shocks for now. As for leaks, well, all old 911s leak at least somewhat. I park over cardboard in my garage. If you can live with it, leave it for now. All in all, I can see you getting 80% of the way there for under $2k (plus maybe another $50 in beer ![]() There's a saying, all 911s are $20k 911s - pay it up front, or in getting it up to par.
Current: 1987 911 cabrio Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster |
Flat Six
Home Alignment of Porsche Cheers, Dale
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport |
