plumb4u2's Avatar
alternator light just came on?
Ok guys I have searched but want your opinion before I proceed
Yesterday I came home from work and pulled in the garage and noticed that the battery light was lite (first time this has happened in my year of owning). I reved the engine and it went out then after bout 30 sec of idle came back on.
I searched some threads and did some checks
my belt is tight and no slipping (I replaced belt this winter as maintenence)
today I checked voltage at battery with car at idle 12.4v...had wife rev to 3k and got 13.4v
So from these checks I believe that alternator needs to be replaced?
Battery was made 09/09
Justin
84 Carrera Targa
98 F-150 4x4
Old 07-16-2011, 01:11 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Does the voltage bounce around a little when measured? If so probably the v regulator.
Old 07-16-2011, 02:57 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
3.2 Alternators.
You should have 14.5V @ 3K RPM's.
Things are pointing to the VR, easy to replace.
Get your system checked out.
Someone sent me this.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 07-16-2011, 03:01 PM
plumb4u2's Avatar
i did not notice reading bouncing around but i will recheck
if it is the VR would it make sense for me to replace just that or the whole alt.
i believe i saw our host sells vr for 65.00 for that much wouldnt it be better to replace whole unit
i have no history on this alternator
Justin
84 Carrera Targa
98 F-150 4x4
Old 07-16-2011, 03:19 PM
wwest's Avatar
Miles...??
High miles....
Alternator slip ring brushes have worn out.
Old 07-16-2011, 06:00 PM
If it's an un-modified '84. Then the VR will be integral to the alt. Change out the whole unit....
Old 07-17-2011, 05:43 AM
plumb4u2's Avatar
yes un-modified '84 only 91k miles
Autozone has a duralast alternator, has any one used this as replacement
165.00 vs almost 300.00 from our host for a bosch
I know the VR is integral to the alt but it can be replaced just dont think its worth the gamble
Justin
84 Carrera Targa
98 F-150 4x4
Old 07-17-2011, 07:17 AM
RETIRED
Joe Bob's Avatar
I prefer to have a local shop rebuild mine....
2012 ML350 3.0 Turbo Diesel
Old 07-17-2011, 09:59 AM
plumb4u2's Avatar
Hey Joe Bob, or anyone else, what type of shop will rebuild Alt.... meaning what should I look up in the phone book
Justin
84 Carrera Targa
98 F-150 4x4
Old 07-18-2011, 03:41 PM
RETIRED
Joe Bob's Avatar
altenators, starters, automotive/electrical, or ask the local wrench for a referal. Good wrenches don't buy Manny, Moe and Jack crap.
Old 07-18-2011, 03:42 PM
Local shop.......
Whenever I have problem with either my starters and alternators, I simply pull them out and bring the unit to my local electrical shop. It takes a few minutes for these guys to determine the condition of your unit/s unless you are familiar or have the apparatus to make the tests. My starter is 15 years old after the rebuild and still going strong.
Tony
Old 07-18-2011, 04:12 PM
