Member 911 Anonymous
Simply removing the bow tie helps alot in my case.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Here is the crankshaft pulley, it basically uses the stock pulley holes as stops for a quite solid pulley to drive the compressor. I was very skeptical but went ahead with it and it so far is flawless.....
It fastens with a new crankshaft bolt (longer of course) and since you are pulling the engine mount off to put on the compressor mount, well...you get the picture ![]()
It is possible to do a decent job of charging your 134a system at home.
