Member 911 Anonymous
DRACO A5OG's Avatar
Simply removing the bow tie helps alot in my case.
'85 Carrera Targa
PCA/POC
Old 07-21-2011, 07:53 PM
Here is the crankshaft pulley, it basically uses the stock pulley holes as stops for a quite solid pulley to drive the compressor. I was very skeptical but went ahead with it and it so far is flawless.....
It fastens with a new crankshaft bolt (longer of course) and since you are pulling the engine mount off to put on the compressor mount, well...you get the picture
Old 07-21-2011, 08:17 PM
It is possible to do a decent job of charging your 134a system at home.
Old 07-21-2011, 08:35 PM
