LinkBack | Thread Tools | Rate Thread |
What is the highest offset you can use on an SC with 8in wide front wheels?
Like the title says, I'm trying to figure out a few things with width and tire size so I need to know what's the highest offset you can run on the front of an SC with 8" wide wheels.
that911.tumblr.com |
TT
Tom Tweed Early S Registry #257 R Gruppe #232 Rennlist Founding Member #990416-1164 Driving Porsches since 1964 |
ET23.3 has been done but I wouldn't recommend it, I have ET25 on mine and it's good for 225-235 tire width, 25 up to 31 is probably the bet area to be especially w/ 245s
Thanks a lot guys.
Bill do you think I could fit a 9" wide wheel in the front with rolled and pulled fenders and a slightly stretched 225 or 235 tire? I've never had a problem fitting "aggressive" wheel/tire combos, but I want to know if this will be fender work of if a 9 is just impossible without flares.
