strut questions need asap help!!
Help I just recieved new Bilstein HD shocks for my Bilstien struts.I did the bench test and , The rebound. and the compression rate is different. Does that matter..I just put them both outsde to get an even temp. to try again..Do I have a bad new shock??? . One of them is clearly slower rebond by about 3 seconds in return..TIA
Old 03-09-2002, 11:56 AM
Early_S_Man's Avatar
Porsche Crest
The brand doesn't matter ... all 'normal' shocks have a higher damping rate for rebound than compression!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 03-09-2002, 12:04 PM
Warren should Both new shocks match each other in speed of rebound. i.e. Both raise at the exact same speed.
Old 03-09-2002, 12:08 PM
Porsche Crest
With the 'de Carbon patent' high-pressure monotube gas shock designs , of which Bilstein are the most common example, it depends on how much gas pressure has bled off on the used shock. If there is no sign of oil leakage ... I would expect a worn-out shock to return faster on the return stroke than a brand-new replacement.
Warren Hall, Jr.
Old 03-09-2002, 12:15 PM
Warren Thanks for a speedy response But my questions is on both of my BRAND NEW shox The rebound rate is different. 7 seconds different side by side on the new shocks . one of the "New "shocks rebounds alot faster than the other "NEW" shock
Old 03-09-2002, 12:20 PM
