How do I remove the rear view mirror button off of the glass?
Hello,
I just installed a new windshield and didn't realize that the metal button had a taper and of course my 50/50 chance wasn't in my favor! What solvent will release the adhesive, or am I out of luck?
Thanks, Rutager
Rutager West
Old 07-27-2011, 07:16 PM
It took 3 attempts before the adhesive would stick my button to the new windshield so you could probably gently tap it from the side to get it off.
1983 Porsche 911SC - Arrow Blue lightweight '74 Carrera look
http://forums.pelicanparts.com/porsche-911-technical-forum/498568-overdue-intro-sc-hotrod-project.html
Old 07-27-2011, 07:32 PM
Rear view mount removal.......
Originally Posted by rwest View Post
Hello,
Thanks, Rutager
Rutager,
I used a heat gun to re-position my rear view mirror. A hair dryer will work too. Apply the hot air directly to the 'button' from inside the car. Move back and forth the direction of the hot air to spread the hot air coming in contact with the windshield. Once the area around the 'button' has been heated or warm-up, work on the 'button' to melt the adhesive between the button and the glass. When the temperature gets hot enough to make the adhesive to flow/melt, you could pull the 'button' or use a razor glass scrapper to get it off the glass.
Tony
Old 07-27-2011, 07:41 PM
Got it off with a razor blade, just carefully work the blade at the edge (obviously) and it will eventually break the seal. Try the heat first, it probably is easier. Steve
1970 911T SOLD
1989 3.2 Carrera
2013 991 Carrera S
Old 07-28-2011, 09:26 AM
wwest's Avatar
grip tightly with visegrips and twist, heating the button first wouldn't hurt.
Old 07-28-2011, 09:48 AM
Hi
Targa Me's Avatar
LOL, a friend of mine tried to remove that button from his windshield and it ended up coming off, taking a chunk of glass with it.
FYI.
"A good sense of humor is the best thing to have in your toolbox when working on these cars."
Quote by Charles Freeborn, Pelican.
Old 07-28-2011, 11:01 AM
Razor blade and acetone (nail polish remover)
Old 07-28-2011, 11:09 AM
moneymanager's Avatar
Careful. It's remarkably easy to break the windshield doing this.
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 07-28-2011, 11:38 AM
Thanks for all the suggestions; I think I'll try acetone first and then some heat. I figured it would be pretty easy to chip or break the glass, so I'll go in the order of least risk.
-Rutager
Rutager West
Old 07-28-2011, 02:32 PM
Make Bruins Great Again
Por_sha911's Avatar
+1 and take your time. Rush and you'll take out a chunk of glass. Also, be fanatical about cleaning both surfaces before reinstalling the button or it will not last too long.
Joe
Old 07-29-2011, 09:26 AM
They sell the special glue for reinstalling the button. It comes with a cleaning dab and the glue. It is similar to crazy glue, but do not use crazy glue for this as it does not last.
Old 07-29-2011, 10:33 AM
Send a message via Skype™ to hangar21
You can also use MEK(methyl Ethel ketone), be sure to use protective gloves. After It soaks for a 5 to 10 minutes, it pop right off.
Old 07-31-2011, 01:57 PM
mnewport's Avatar
+1. I used the same method.
The Uncertainty Principle. It proves we can't ever really know...what's going on. So it shouldn't bother you. Not being able to figure anything out. Although you will be responsible for this on the mid-term. -Larry Gopnik
Old 07-31-2011, 02:14 PM
Do you know the toxicity level of MEK?
hangar21,
Have you actually done this application? Exposing yourself with MEK inside a car is hazardous to your health!!!! MEK is toxic and should be used in a well ventilated area preferably in a work place with exhaust hood. Unless you have respiratory equipment to prevent inhaling the fumes from MEK, I would think twice to use this nasty chemical in a tight confinement. Just my two-cents.
Tony
Old 07-31-2011, 04:37 PM
My car is a Targa, so if I do it in the driveway, the MEK fumes wouldn't concentrate like in a coupe, but I will keep that in mind. It does seem like several people have had good luck with heat though. I needed the car Friday night, so I haven't tried anything yet- maybe Monday.
-Rutager
Rutager West
Old 07-31-2011, 04:47 PM
Detached Member
Hugh R's Avatar
Ain't that the truth!
Hugh
Old 07-31-2011, 04:48 PM
Use a hair dryer not as blow torch.......
You'll break the windshield if you expose it to a thermal shock. The trick is heating the surrounding area initially to spread the heat and proceed to make the glue to flow or melt. Make a sweeping movement or stroke of the dryer over the 'button'. Keep the dryer moving all the time and you'll remove the button in seconds. You don't need to heat the glass per se but need to break the bond between the glass and the 'button'. The epoxy glue has a much lower Tg than glass (Si). Tg stands for thermal glass transition temperature.
There is a big difference between myth and facts.
Old 07-31-2011, 05:15 PM
burgermeister's Avatar
A .009 or .010" electric guitar string works very well, with basically zero risk to the windshield. Just saw back & forth (use gloves to hold the string) - the friction melts the glue, without creating enough heat to harm the glass. Takes approx. 2 - 3 minutes to "saw" the button off.
Edit: Try not to stop 1/2 way through, or if you do, pull the string out immediately. It will stick, and can be difficult to get going again.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 09-09-2011, 01:03 PM
Great idea. But what am I going to do about my guitar?
jhtaylor
santa barbara
Old 09-09-2011, 01:14 PM
You don't have a supply of spares sitting around? The high E seems to always be the first to go ...
Old 09-09-2011, 02:20 PM
