Need a Mass flow Sensor for 1989 911
My 1989 911 needs a mass flow sensor can anybody help me out? Don't really want to pay the price for a new one.
Old 08-02-2011, 05:38 AM
Diss Member
Quicksilver's Avatar
Why do you feel need a new AFM for your engine? Some of the common failures are easily fixed as a Do-It-Yourself afternoon project. (The common one is changing the wiper arc.)
BTW, just a technical detail: It isn't a a Mass Flow sensor. It is an Air Flow Sensor. A MAF is a sensor designed to detect the mass of the air going through the sensor. The way this is done in an automotive sensor is they use a heated wire where they can calculate how many air atoms/molecules come in contact with the wire by how much heat they absorb from the wire.
There are some MAF conversions but they are expensive and they haven't been shown to give any performance improvement on stock motors when tested by a well known independent engine builder.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 08-02-2011, 06:18 AM
Friend of Warren
I believe the 911 AFM's are all the same from 1984 through 1992.
Kurt V
Old 08-02-2011, 06:46 AM
muck-raker
kidrock's Avatar
if you really feel as if you need to replace your AFM, try a good used one from Weekend Rides LLC. Good prices and Rick has been a pleasure to deal with.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 08-02-2011, 08:45 AM
The reason for asking about the air flow sensor is this is what the mechanic said was wrong. The sensor was damaged by an engine backfire. I'm not familiar with this myself, and know very little about it. I just thought 1400.00 bucks was a little much for a sensor. If you have any advice or could help in some way it would be greatly appreciated.
Old 08-02-2011, 08:48 AM
RETIRED
Joe Bob's Avatar
I've seen more than a few on eBay. The dismantlers have them. Parts Heaven, dC Automotive, Patrick Motorsports....avoid LAPD.
Old 08-02-2011, 09:01 AM
Chris Scott's Avatar
I just bought a rebuilt one for my 87 911 from Parts Heaven for $250 and works great.
Call Al or Spencer at 510-782-0354. They ship
By the way this takes about 25 minutes to do the swap. It is plug and play no adjusting.
Hope this helps
Chris
Old 08-02-2011, 09:10 AM
Chain fence eating turbo
Rock Auto has one for $150 + $75 core charge.
I would be very interested in your old one.
Old 08-02-2011, 09:52 AM
Nine9six's Avatar
I found one on this forum under, "911 Used Parts Classified." $75 plus shipping. Still running strong.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 08-02-2011, 11:57 AM
When did you find it? I've looked recently and never saw one.
Old 08-02-2011, 01:23 PM
Targa, Panamera Turbo
M.D. Holloway's Avatar
What are the symptoms of knowing / thinking you need one? Stalling? Unable to start?
Michael D. Holloway
https://5thorderindustry.com/
Old 08-02-2011, 02:21 PM
dshepp806's Avatar
+1.
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 08-02-2011, 02:27 PM
Diss Member
Can't imagine a backfire hurting the AFM off of a DME car. It would blow up the rubber elbow instead.
Any chance you car is a Turbo? A CIS airbox explosion would be much more likely.
Assuming it is an AFM I would search this forum for how to adjust and test the AFM. It is a pretty simple and pretty indestructible piece of equipment.
Old 08-02-2011, 02:55 PM
backfires bend the flap, then it either drags or passes too much air at idle/low rpm. sometimes you can pry it straight with a couple of screwdrivers. same through 1994.
206 637 4071
Old 08-02-2011, 07:43 PM
Diss Member
Wow! Wouldn't have guessed that the barndoor would bend before the rubber would go.
I would assume you could take another one with toasted electronics and put them together to make a good one for cheap.
Old 08-02-2011, 08:43 PM
Eventually they wear out. I bought an almost new one dirt cheap from Einmalig a few years ago. It's in my stash of troubleshooting spares.
Old 08-02-2011, 08:47 PM
