Fixed the alarm!
Finally after going through and finally finding the Alarm control unit and the alarm relay. We tested everything and took apart the alarm unit and lo and behold a burnt solder joint in the alarm unit not allowing the fuel pump to get fuel. After a resolder it's finally running and the real cleaning/updating/tuning can begin. The mechanic said atleast having it sit there kept the miles off of it at 21k. It turns out the old mechanic took the ground for the alarm to move for the new radio which shorted the alarm.
Old 08-02-2011, 12:16 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Very Cool
'85 Carrera Targa
PCA/POC
Old 08-02-2011, 07:25 PM
muck-raker
kidrock's Avatar
Good Lord, what a hot mess....I've been trying to track down some hot start issues, and finally may have tracked it down to an alarm wiring harness as well.
You'd think we were driving MG's, Jags or freaking Land Rovers sometimes. "Bulletproof" motors with electrical systems thrown in as an afterthought, it seems. I realize it's the aftermarket stuff which throws the cars off, but I've never had these types of issues with any other vehicle I've ever owned.
Anyways, it's always good to hear when somebody does a DIY and figgers it out.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 08-03-2011, 06:42 AM
dshepp806's Avatar
Hope the electronics didn't take a hit (burned=usually not good).
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 08-03-2011, 06:51 AM
Tested the resistors and board and everything was running fine. Now time to clear up the dust that settled on it... Also are there any places that sell silk grey shift knobs? I noticed pelican only has black...
Much deserved pictures (still torn apart while I'm at it gotta get the little things I bought for it put back in...)
In the background there's a Z28 and an assortment of R129 SL mercedes.
Old 08-03-2011, 07:49 AM
Can anyone comment on those relays? I have no idea why they're all red is this something worth switching out with the brown/black ones or is it suppose to be like that?
Old 08-03-2011, 09:38 AM
RETIRED
Joe Bob's Avatar
Now that it's fixed consider removing it.....
2012 ML350 3.0 Turbo Diesel
Old 08-03-2011, 10:23 AM
Alright just gave its maiden start. It's going to need the gas tank bled as it was smoking more than a can seafoam would make it smoke. Also any recommended brands of oil and which type of oil? My local shop carries Mobil 1 Castrol and Royal Purple. I'm guessing go with royal, but need to know the viscosity it takes.
Oh and while fixing it I put a SW chip in it...
Old 08-03-2011, 11:48 AM
RETIRED
Joe Bob's Avatar
Valvoline 20/50 VR1 Racing....
Old 08-03-2011, 11:53 AM
Local doesn't carry valvoline :/
Old 08-03-2011, 11:54 AM
RETIRED
Joe Bob's Avatar
Auto Zone.....order it. Take a look at the ultimate oil thread.
Old 08-03-2011, 11:56 AM
Oh darn one thing after another.... The car took 10L of oil 5 of them were VR1 racing and the other 5 were Valvoline Conventional 20w/50 (the guy messed up the first time around).
But a finally check revealed stuck calipers as I'm working on these calipers should I upgrade to brembos or the sort or stick with the stock ones and get them rebuilt/new? If brembos anything that will fit under stock fuchs?
Old 08-03-2011, 05:38 PM
